Relay to Cut Off Headlight When Starting
- PLUMMEN
Re: Relay to Cut Off Headlight When Starting
18 Sep 2010 03:33
larrycavan wrote:
hes learning folks! :woohoo:PLUMMEN wrote:just keep your bike tuned up and it wont be a problem! :laugh:
i always wire my lights to come on when ever the key is on,i want people to see me coming day or night
They can see Otto in the dark without any lights....He's got a chemical glow :laugh:
[just kidding otto]
Seriously though..... A properly tuned KZ starts in about a half a revolution of the motor.....So where is the real need for this?
- larrycavan
18 Sep 2010 06:17
bountyhunter wrote:
So the bottom line is you're saying the battery will last longer.... How much longer do you figure?
larrycavan wrote:It's the design of a wet cell lead acid battery, and the fact that bikes use very small batteries. The starter needs a lot of current which pushes the battery for the internal impedance. As batteries crank out amps, the material on the plates is consumed and gradually falls off and collects in the bottom of the battery (in the sediment tray). These batteries actually are used up based on how much current they deliver and it is not linear. The other thing is as the battery ages (and it's internal impedance goes up) it can stay in service longer since the battery demand during start is less. It basically both reduces battery attrition and also extends the service range since the demand now requires less CCA (cold crank Amps) to start the bike.
- larrycavan
18 Sep 2010 06:19 - 18 Sep 2010 06:23
AtLarge wrote:
If you run out of gas.....the factory addressed that with the PRI setting on the petcock
www.impactbattery.com/motorcycle-atv-sco...6&AdGROUP_K=YB14L-A2
Sure seems to me like a more logical solution to a problem that doesn't really exist to begin with...but hey....I'm funny like that :huh:
I like it. When I get a rountoit I just might try this. Granted for a "properly" tuned bike it may not be a concern but if you've ever flooded or ran the system out of gas because you forgot to turn the petcock on well... we all make mistakes. I agree with BH. Anytime you can lessen the cranking you might save your butt later. Plus I switched up to an automotive headlight and I know it doesn't take long to suck the life out of a battery when your brake light is stuck on and you don't know it. Seems like a worthwhile mod to me. After all, cars cut the headlights too while cranking.
Last edit: 18 Sep 2010 06:23 by larrycavan.
18 Sep 2010 11:05
bountyhunter wrote:
I also enjoy relatively long battery life with rider controlled on-off light switch in right hand handlebar switch gear of Z1 and KZ900.
Am wondering if KZ750 twin is harder to crank over than a four cylinder.
Z1 and KZ900 can actually be started by using hand instead of foot on the kick starter.
PLUMMEN wrote:Yes (me too), but you want the lights OFF when you crank the starter. Lead acid batteries are excruciatingly sensitive to depth of discharge and actually "wear out" based on cranking current out. Worse, the starter is already a severe load so throwing the lights on top is like exponentially worse.just keep your bike tuned up and it wont be a problem! :laugh:
When I got my bike new in 1979, the first battery lasted 14 months (2 months outside the warranty). Must be a fluke I thought. I bought a REALLY GOOD replacement that lasted 18 months. same for next one.
I rewired the bike to disconnect all the lights at startup and I average about 6 YEARS per battery and they are the JC Whitney cheapo ones.
- bountyhunter
18 Sep 2010 11:31 - 18 Sep 2010 11:32
larrycavan wrote:
In the case of my own KZ-750, the fisrt three batteries (prior to modification) averaged maybe 15 - 18 month life. After mod, at least 5 years. In a couple of cases, I replaced batteries that could still turn the starter but were old enough I wanted a new one. No guarantees, but that's the ballpark I got.bountyhunter wrote:larrycavan wrote:It's the design of a wet cell lead acid battery, and the fact that bikes use very small batteries. The starter needs a lot of current which pushes the battery for the internal impedance. As batteries crank out amps, the material on the plates is consumed and gradually falls off and collects in the bottom of the battery (in the sediment tray). These batteries actually are used up based on how much current they deliver and it is not linear. The other thing is as the battery ages (and it's internal impedance goes up) it can stay in service longer since the battery demand during start is less. It basically both reduces battery attrition and also extends the service range since the demand now requires less CCA (cold crank Amps) to start the bike.
Last edit: 18 Sep 2010 11:32 by bountyhunter.
- bountyhunter
18 Sep 2010 11:34 - 18 Sep 2010 11:35
larrycavan wrote:
When I bought a new bike and realized over it's long (hopefully) life I would be dropping about $70 on a new battery every year and a half, I definitely had a problem. And this fixed it.
Last edit: 18 Sep 2010 11:35 by bountyhunter.
- bountyhunter
18 Sep 2010 11:36
Patton wrote:
Compression new is about 160. I have never been able to kick it over.bountyhunter wrote:PLUMMEN wrote:Yes (me too), but you want the lights OFF when you crank the starter. Lead acid batteries are excruciatingly sensitive to depth of discharge and actually "wear out" based on cranking current out. Worse, the starter is already a severe load so throwing the lights on top is like exponentially worse.just keep your bike tuned up and it wont be a problem! :laugh:
- bikerjim
- 1986 T-type Regal
30 Sep 2010 11:02 - 30 Sep 2010 11:03
Must be something about these twins. I can't kick mine over either without punishing myself and the bike. I think I did start it once, maybe, that way.
My old Sears Allstate moped had a compression release lever which helped. I guess that probably would not have worked on this sophisticated machine.
You would think that Kawasaki would have addressed that issue. Or, maybe I'm just a 280 lb wimp.
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
Last edit: 30 Sep 2010 11:03 by bikerjim.
- steell
30 Sep 2010 14:04
bountyhunter wrote:
On the 79 750 twin it's just a matter of installing the 78 switch pod and plugging in the on/off light switch to the original wires under the tank. The original plugs are there, Kawasaki just installed a plug in jumper to connect the two wires when they did away with the light switch. Remove the jumper and install the switch pod, easy.
I kick start my 750 twin fairly often, two kicks when cold, one when hot. 170 psi compression and my normal weight is 235 (won't mention current weight).
650ed wrote:My 1979 has the handlebar mounts that still have the lettering for the light switches but no switches. It would actually be a lot of work to install the older ones (with switches) and wire the switches in. The relay is really an easy installation. The lines are all available near the fuse box. It's also "idiot proof" since it restores stock function automatically after starting.My KZ650-C1 has an On/Off headlight switch on the right handlebar control. Could owners of later models just swap their control switch with one like mine so they could decide when the light comes on? Ed
For the record: having the headlight on with the key is also state law in many places so changing it might get you a hassle trying to register the bike or sell it.
- bountyhunter
30 Sep 2010 16:05
My typical weight used to be 165. Add the skinny chicken legs to bad lower back pain and kick starting is a real bugger.
- steell
30 Sep 2010 20:01
Guess I should re-phase my statement, I kicked started my 750 fairly often, last year, when I could actually ride. Haven't had the strength to hold the bike up since I started chemotherapy in March.
Howsomever, the cancer appears to be cured (beat the less than 50% odds of survival), and my last chemo will be a week from next Tuesday, so I'm hoping to ride it yet this year
- AtLarge
30 Sep 2010 20:33
I'm 5'10'' and 185#. Now that the ambient has dropped and 50W still in the crankcase there ain't no kickin for me.
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
1994 BMW K1100RS
