kz1000 dyna ignition wiring?
- kz1k
- You Cant Fix Stupid!
14 Sep 2010 14:53
1978 KZ1000A2
- kz1k
Re: kz1000 dyna ignition wiring?
14 Sep 2010 14:53
1978 KZ1000A2
- kz1k
14 Sep 2010 14:54
1978 KZ1000A2
- kz1k
14 Sep 2010 15:29
1978 KZ1000A2
- kz1k
14 Sep 2010 15:30
1978 KZ1000A2
- kz1k
14 Sep 2010 15:31
1978 KZ1000A2
- loudhvx
14 Sep 2010 15:51
Looks like you got the right diagram for the Dyna III. Sorry about saying it was a Dyna S earlier. The two look similar.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- bill_wilcox100
14 Sep 2010 17:35
Just an observation... do not use a Splice Connector as shown on your diagram. They are an Isolation Displacement type connection and have been found to be very unreliable by many, many members here. Solder directly and use Shrink Tubing for the best results.
Best of success.
Bill
Best of success.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- MFolks
14 Sep 2010 17:55
3M and several others make this type of splice,it's a real problem when moisture gets into the metal part and corrosion sets in, making for an intermittent connection.
Try being under a trailer on the side of the road troubleshooting why brake lights and running lights are not working during a heavy rain!
- otakar
15 Sep 2010 05:53
I use the new stile crimp connectors all the time. They now come with a "heat-shrinkable" jacket that once you crimp the connection you heat it up and the outer jacket shrinks around the wire and seals out all moisture.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
