I need a tool!
  • kzluke750
  • kzluke750's Avatar Topic Author
I need a tool!
14 Sep 2010 05:00
#398530
Does anyone know where I can find a "Alternator removal tool" part #57001-254 or #57001-1099? I need to replace the starter clutch on my '82 CSR 1000.
1980 750 LTD Stock
Motors run on electricity, engines run on fuel.
-Jerry Baxter
  • otakar
  • otakar's Avatar
Re: I need a tool!
14 Sep 2010 05:23
#398538
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is a good place
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Motor Head
  • Motor Head's Avatar
Re: I need a tool!
14 Sep 2010 06:32 - 14 Sep 2010 06:48
#398554
There was a thread on this not to long ago, some said the bolt from the triple trees had the same thread, some said the rear axle. On mine it was the rear axle, and I think yours would be the same. Take out the rear axle and it should thread into the end of the rotor and take it off. Be careful as you can loose the magnetism, or have the magnets come loose as they are glued to the rotor. It will take a lot of turning force to get it off, then when putting it back on the FSM recommends cleaning the taper on the crank and the mating taper in the rotor with a quick flashing solvent, then re-torquing to 116ft lbs. Some blue loctite on the bolts a good Idea.
Last edit: 14 Sep 2010 06:48 by Motor Head.
  • otakar
  • otakar's Avatar
Re: I need a tool!
14 Sep 2010 06:41
#398559
What ever you do,"do not tap the side of the rotor"!!! You will crack the magnets and the unit will be useless after that. Even one crack anywhere will change the magnetic field threw the Alternator. You can tap the end of the puller if you wish or heat up the center very carefully with a torch as you are tightening the bolt. make sure that you use something like "neverseeze" on the threads so you do not gall the threads. I just tighten the bolt as far as I feel is safe and than start heating the center. It will POP off quite quickly.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • kzluke750
Re: I need a tool!
14 Sep 2010 07:32
#398583
Thank you all. I never considered the bike having the tool "built in". Thats the cheap tool I was looking for! Thanks Again!
1980 750 LTD Stock
-Jerry Baxter
  • Motor Head
Re: I need a tool!
14 Sep 2010 07:34
#398586
You should read the procedure in the Manual, if you don't have 1 there is a pdf of 1 on KZR. It will be of great help, and may keep from having a woopsie.
  • kzluke750
Re: I need a tool!
14 Sep 2010 08:10
#398600
Thx. I do have a manual.
1980 750 LTD Stock
-Jerry Baxter
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: I need a tool!
14 Sep 2010 08:33
#398618
Good info here...
Tighten, whack, tighten, whack... it seems to be stuck and not moving, but trust me, its about being able to tighten the bolt further, not -much harder whacking.
Heat works good if your comfortable with it. makes the job half the effort.
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • loudhvx
  • loudhvx's Avatar
Re: I need a tool!
14 Sep 2010 08:58
#398625
Just to add to Otakar's warning, heat and impact are two things that reduce magnetism in magnets, so keep both to a minimum, and only in the center, never on the sides.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: I need a tool!
14 Sep 2010 18:19
#398766
dont forget the ball bearing ! B)
  • donthekawguy
  • donthekawguy's Avatar
Re: I need a tool!
14 Sep 2010 18:47
#398777
What he said-just make sure you use a big one or you will mess up the threads in the crank. Dont ask how I know this.:blush:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • larrycavan
  • larrycavan's Avatar
Re: I need a tool!
14 Sep 2010 19:44
#398792
Kawasaki sold a tool for both the old and new style rotors on KZ900/1000/1100.
The tool is threaded on each end with a generous hex section in the middle. You get the tool and cut it in half. Then get some 5/8" round stock, cut two pieces 5" long. Weld those to hex section on each piece in the form of a T.
Thread it the puller and wack the T Handle with a hammer. Rotor comes right off without risking and magnet damage.
It takes longer to thread the puller into the rotor than it does to get the rotor off the crank....Been doing them that way since 1985...
