KZ 900 WIRING HELP PLEASE
  • Old Man Rock
  • Old Man Rock's Avatar
Re: KZ 900 WIRING HELP PLEASE
14 Sep 2010 05:40
#398542
To add to the Dyna stuff....
Follow the link and there's a write up on how I set my Dyna up on my 76KZ900... Maybe it will help...
kzrider.com/index.php?option=com_docman&...d&gid=449&Itemid=108
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • otakar
  • otakar's Avatar
14 Sep 2010 05:45 - 14 Sep 2010 05:52
#398543
No eBay APP ID and/or Cert ID defined in Kunena configurationIt sounds like you could use one of these. Everything you will need (short of the tools)is in this factory service manual. Including all of the weiring diagrams, torque specs,timing requirements, and required periodical adjustments.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 14 Sep 2010 05:52 by otakar.
14 Sep 2010 10:34 - 14 Sep 2010 10:46
#398646
If it's a Dyna III ignition, see link below to installation instructions, courtesy of Z1E (Z1 Enterprises).
Dyna III has a separate controller box that's not fitted under the points cover.
Dyna III was superseded by Dyna-S without a separate controller box.
Click here > www.dynaonline.com/skins/downloads/instruct/D32-1_32-2.pdf
Dyna III backing plate (see image below) may have slotted holes for the mounting screws (for timing adjustment) or non-slotted holes.
Good Fortune! :)
Last edit: 14 Sep 2010 10:46 by Patton.
  • loudhvx
  • loudhvx's Avatar
14 Sep 2010 15:46
#398711
Oops, I should have said it's a "Dyna S or Dyna III". It looks far more likely to be the Dyna III, not Dyna S.
