brake light on?
- timber
brake light on?
15 Apr 2006 16:51
ok, i got rid of my fender. cleaned up the rear area. welded a brakect on an installed new lamp. the lamp works properly. the running light, the brake light all works. know i have a brake warning light up on the dash panel. why? and what did i do wrong? :blink:
when the batteries in the camera charge up i will show some pictures of what i did.
thanks
thanks
- timber
Re: brake light on?
15 Apr 2006 17:17Attachments:
- timber
- arobsum
Re: brake light on?
15 Apr 2006 17:31
when you reassembled the tail end you must have pinched a ground wire. i believe thats what turns the warning light on.
- timber
Re: brake light on?
15 Apr 2006 20:13
thanks arobsum, i went out and checked everything. i ended up reversing the power and the ground wires. once i knew what the warning light meant i was able to track it down easy enough and make the corrections needed.
- sbjones
Re: brake light on?
23 Apr 2006 23:06
hey timber, i recognise that light!!!!! that is the same one that i used to do my rear fender eliminator!!!!
they fit perfect don't they!!! ha ha gotta love truck/trailer parts!!!!!
- sbjones
Re: brake light on?
23 Apr 2006 23:08
is yours led? that is what i used. not sire if you remember that.
