Magneto question
  • mjkawa
  • mjkawa's Avatar Topic Author
Magneto question
15 Apr 2006 15:42
#39752
anyone here ever adapt a magento to your kz?
My assumption is that this will eliminate the battery?
My starter clutch is shot, so I have to kick start anyway.
I like the idea of loosing the weight.
Are there any other drawbacks? And where could one get these parts?
Thanks
82 KZ-1000-J
77 KZ650 B
  • wireman
  • wireman's Avatar
Re: Magneto question
15 Apr 2006 16:05
#39759
ive got a belt drive one i took off an 80 ltd,they look neat but your limited on the ignition advance.im going to run a dyna 2000 when it goes back together.:whistle:
  • Fossil
  • Fossil's Avatar
15 Apr 2006 20:46
#39824
Talk to Buck Burgess at Goblin Millworx
www.goblinmillworx.com/
He's a member here, "Goblin".
  • loudhvx
  • loudhvx's Avatar
15 Apr 2006 22:37
#39839
If your bike uses a permanent magnet for the alternator/flywheel, you may not even need a magneto.
I can go batteryless on my 550 as long as I replace the battery with a 6000 to 12,000 micro-farad (35v to 50v) capacitor.
I don't think it will work if you are using a Dyna ignition. It should work with a stock ignition.
  • mjkawa
17 Apr 2006 10:19
#40206
Thanks for all the info.
I like the capacitor idea.
Is there any performance advantages (besides batery weight), or disadvantages?
Should I just choose a capacitor in that range? Is larger or smaller better? or just find one that works?
Thanks for the ideas.
82 KZ-1000-J
77 KZ650 B
  • loudhvx
  • loudhvx's Avatar
17 Apr 2006 11:17
#40213
No advantages other than weight. The disadvantages are possible loss of voltage at idle. There is another thread going right now that addresses that issue.
Here:
kzrider.com/component/option,com_joomlab...id,4/id,40215/#40215
Post edited by: loudhvx, at: 2006/04/17 14:19
