79 kz1000B3 wiring Now In Color
- loudhvx
06 Sep 2010 10:55 - 06 Sep 2010 10:57
A while ago someone mentioned the diagram for the 1000B3 was only available in black and white. I said I'd colorize it when I got a chance.
kzrider.com/index.php?option=com_docman&...w&gid=130&Itemid=108
It's based on the pdf Mcdroid provided.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 06 Sep 2010 10:57 by loudhvx.
- Old Man Rock
Re: 79 kz1000B3 wiring Now In Color
06 Sep 2010 11:06
Added to the downloaded wiring diagrams.... Thanks Guys!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
06 Sep 2010 11:07
isnt it the same as the a3 wiring ? my a3 diagragm is in color
- loudhvx
06 Sep 2010 11:53 - 06 Sep 2010 12:02
I think (but memory is fuzzy), is the A3 is electronic ignition? B3 is points. The E model is electronic in 79.
Either way, I didn't see an A3 diagram in the filebase.
Can't use (some or all) 78 diagrams since they use seperate reg and rec.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 06 Sep 2010 12:02 by loudhvx.
