Electrical poor VDC at coils
- damonrepko641
06 Sep 2010 09:37
Coil voltage 8.46 key on kill switch on, unplug red wire from Dyna S voltage at Coil goes to battery voltage
- otakar
Re: Electrical poor VDC at coils
06 Sep 2010 12:23
What is it with engine running?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- damonrepko641
06 Sep 2010 12:32
Hard to say very hard to start, very poor idle, run out of battery if you get it to start, symtoms dont stay the same, got typical answers of change jetting, etc.
- otakar
06 Sep 2010 12:38
I would go threw the weiring harness and clean all the connectors. Clean the ignition switch and the kill switch. What bike are talking about? It would help to know.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- damonrepko641
06 Sep 2010 12:44
I have 2 76 900s so parts swapping is easy, got carbs back from shop said they were trashed, would hardly run green bike (problem bike) throw them on other bike runs great vs29mm smooth bore, Ijust replaced all connections at coil Green dynas did'nt change anything. Without rambling bike is far from stock, and can't run with my other 9
- Old Man Rock
06 Sep 2010 15:52
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- damonrepko641
06 Sep 2010 16:15
Thanks for the input, here is what i found, off off-run- off switch yellow wire red trace unplug it at first conn. from switch, and rapid battery drain stops, but also no coil readings.
- Old Man Rock
06 Sep 2010 16:24
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
06 Sep 2010 16:27 - 06 Sep 2010 16:32
Minimum wiring....
You can actually bypass the ignition switch and On/Off Kill switch if you want through a 20 amp SPST switch and in line fuse if you want to get even further bare bone.....
Possibly your Dyna is whacked/shorting....
Get to minimum wiring and go through electrical measurements and testing.....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 06 Sep 2010 16:32 by Old Man Rock.
- damonrepko641
06 Sep 2010 16:45
Had brand new dyna on shelf install resulted in same results what is really strange is when you turn run switch to run with meter connected to battery voltage drop looks like a gas pump in reverse.
- otakar
06 Sep 2010 16:57
Your Dyna should consume about 6.5A I have a feeling that there is a short somewhere or something is hooked up wrong. i know that the Dyna hook up is not rocket science, but things do happen. I have a Dyna on my 76 and with a quartz bulb in the headlight the charging system is about peaked out. The charging system is only about 12A The Headlight and Dyna draw about 10A.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
06 Sep 2010 16:58 - 06 Sep 2010 16:59
Not trying to insult where you're 100% positive the Dyna was wired correctly?
Also... One member recently had a partial shorting of the Dyna coil +12Vdc on the coil mounts to frame... May want to check that as well...
Just in case...
Just in case...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 06 Sep 2010 16:59 by Old Man Rock.
