Possible Charging issues?
  • XL777
  • XL777's Avatar Topic Author
06 Sep 2010 08:35
#396471
As some of you know I recently rebuilt my kz1000. Since then I have had a whole host of qwirks (detailed in engine break in concerns) Now I have electrical demons so I thought I would start a new post here.
1. First I have had no issues up until recently. My battery got a bad cell in it so I replaced it.
2. Next my dyna s died so I replaced it.
3. I cleaned and sealed all my connections tight
4. I performed the test to see if I had a battery drain.
5. I tested the battery after a charge (12V, low?)
6. Warmed up the bike battery tested at (11.40v)
7. rev the motor to 4k no change in voltage
8. let the bike run for 15 min tested batter (11.2v)
sounds like the alternator is not doing its job.
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Possible Charging issues?
06 Sep 2010 08:43
#396472
My 76 KZ900 and early KZ1000 are pretty much identical in the electrical charging system...
Follow this post, has the excerpts from my manual to measure the Dynamo, rectifier and regulator circuits....
Also insure your regulator is ideally grounded...
As I just went through recently, lost a Diode bank in the Rectifier, pretty much same symptom....
kzrider.com/index.php?option=com_kunena&...ew&catid=4&id=395137
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • damonrepko641
  • damonrepko641's Avatar
06 Sep 2010 09:33
#396486
New member quick ? for anyone that may have some insight, weak coil voltage, bout 8.46 VDC bike is 76 900 unplug red lead from dyna S voltage goes to battery voltage. Stumped,
would like to figure out problem dont want to start adding relays
  • XL777
06 Sep 2010 09:44
#396489
I just put the charger on my battery and only after 1 hr on the 2A setting it registered full. I tested it and the voltage is only 12.65V. Is it not supposed to be 14.5V?
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
