- Thank you received: 1
GPZ750 Starting Problem
- nicksorg
03 Sep 2010 18:15 #395924
by nicksorg
1982 Kawasaki KZ1000-K2
GPZ750 Starting Problem was created by nicksorg
82 GPz750. I put the carb rack back on my bike after another cleaning session and stting fuel levels. I also pulled the valve cover and checked clearnances.
When I press the starter button, the starter turns the engine over for a few seconds, but then I hear what I can best describe as a rattling/spinnning noise from the starter/middle engine area. I have the ignition cover off, and noticed that when the noise happens the shaft stops spinning. If I keep trying to start it, the same thing repeats. The engine will not start and has a couple of pops every once in awhile from the exhaust. I'm looking for some insight and where to start.
Thanks
Nick
Thanks
Nick
- DFIGPZ
- Thank you received: 122
03 Sep 2010 19:04 #395930
by DFIGPZ
1984 750 Turbo
Replied by DFIGPZ on topic GPZ750 Starting Problem
sounds like a starter clutch problem.
1984 750 Turbo
- TeK9iNe
- What did you do!?!
- Thank you received: 28
03 Sep 2010 19:58 - 03 Sep 2010 20:00 #395944
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic GPZ750 Starting Problem
The starter clutch unit is over spinning the crank. It probly could use some inspection/maintenence. The parts are very inexpensive to replace and its not a difficult job either. You will need the manual.
You could remove the air filter and spray some quick start in there, as the bike should start and run fine after just a couple revolutions.
Good Luck.
Good Luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 03 Sep 2010 20:00 by TeK9iNe.
- jdornski
- 1978 KZ650B2, 1972 H2, 1974 CB500(oops)
06 Sep 2010 10:05 #396494
by jdornski
1978 KZ650B2, 1972 H2, 1974 CB500, 1972 XJ650, 1984 Honda Aero 80, 1933 AJS 350 Big Port(part-owner)
,johndorn@shaw.ca
250-404-0318
Replied by jdornski on topic GPZ750 Starting Problem
My KZ650B2 has same problem. I have replaced the starter with a used one and the problem did not go away. How long would you estimate it would take to fix the problem. There is only about 1 month left of riding weather here, so I am debating to fix it now or make it a winter project?
,johndorn@shaw.ca
250-404-0318
- MFolks
- Thank you received: 540
06 Sep 2010 11:35 #396520
by MFolks
Replied by MFolks on topic GPZ750 Starting Problem
I'd suggest going to
www.kz650.info
and read up on starter clutch replacement. Over at
www.kawasakimotorcycle.org
a member "kopcycle" recommends pulling the engine to be able to work on it as trying to do it in the frame can be tricky.
- jdornski
07 Sep 2010 09:48 #396749
by jdornski
,johndorn@shaw.ca
250-404-0318
Replied by jdornski on topic GPZ Starting Problem - replace starter clutch
I looked this up in my KZ650 service manual, and I would agree that it would be easier with the engine out. My Clymer manual was useless on this topic.
I think I will wait until something else needs fixing before I tackle this. Got to love kick starters!!!!!
,johndorn@shaw.ca
250-404-0318
- kzr750r1
- Thank you received: 9
07 Sep 2010 10:07 #396757
by kzr750r1
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Replied by kzr750r1 on topic GPZ Starting Problem - replace starter clutch
Not going to help the original poster.... He has no kick starter. If I wasn't considering putting the original motor back in my bike I would offer my spare. Sorry... It's 99% the starter clutch problem tough from the description.
- nicksorg
07 Sep 2010 18:52 #396895
by nicksorg
Replied by nicksorg on topic GPZ Starting Problem - replace starter clutch
I tore into it today and I just about have the starter clutch out. The big question now is what needs to be fixed with it, or what do I need to test or look for?
Thanks
Nick
Thanks
Nick
- nicksorg
08 Sep 2010 17:38 #397092
by nicksorg
Well I got the secondary shaft and starter clutch out tonight. According to the parts diagram, it looks like springs, rollers, and pins are the parts that can be replaced. Outside of replacing these parts, is there anything else involved with servicing the starter clutch?
Thanks
Nick
Thanks
Nick
- MFolks
08 Sep 2010 17:40 #397094
by MFolks
Replied by MFolks on topic GPZ Starting Problem - replace starter clutch
Check the shaft the rollers ride on for smoothness, you don't want any rough areas or "Burrs" as this might make the starter clutch hard to dis-engage.
- nicksorg
08 Sep 2010 17:52 #397101
by nicksorg
Thanks. I disassembled the unit. From playing with it a little, it seems the spring tension should be stronger.
Nick
Nick
- MFolks
08 Sep 2010 18:17 #397110
by MFolks
Springs can loose some of their tension due to overheating,I'd order new parts and re-assemble the engine.
