Both Coils Die at the Same Time????????
  • TLH101
  • TLH101's Avatar Topic Author
14 Apr 2006 15:44
#39558
Took my bike for a ride a few days ago, after it had been setting for a few weeks. Ran pretty rough, and #1 pipe was cool, so I figured I had a stuck float valve in #1. Stopped to mess with it, and carb float is OK, so tried to start it, and now no fire on any cylinder. I have power to the coils. Primary reads about 4.0-4.1 on both coils, sencondary is open on both.
Is it just a coincedence that they have both gone bad at the same time, or do I need to look for another problem? :unsure:
  • jbw7300
  • jbw7300's Avatar
  • you can't ride if your fried
Re: Both Coils Die at the Same Time????????
14 Apr 2006 15:54
#39560
probably want to check you ignition, do you have points
or are you running electronic
84 kz 700 a1 sports
  • TLH101
14 Apr 2006 16:08
#39562
Has points ignition. Only about 3-400 miles on the points and condensers. Gaps are correct.
