Charging problem...still
- 2bskor
01 Sep 2010 07:48
My regulator was replaced (the ground wire was melted??) with another good regulator still no charge. I took the stator out looked it over and found a broken wire in one of the copper windings that went from one winding to another, so I solder it and tried that but after driving the bike the battery continues to go down in voltage.
The funny thing is if I try to get a reading from my multimeter across the battery I can't get a reading because the display jumps all over the place, so I tried a new meter and the same thing happens, but only when the engine is running ?????? Any ideas.
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
- Motor Head
Re: Charging problem...still
01 Sep 2010 07:54
Sounds like a lot of AC ripple, used R/R bad, leaking diodes.
- 2bskor
01 Sep 2010 08:36
Did the same with the last r/r where are the diodes located
and ac ripple ??
and ac ripple ??
- loudhvx
01 Sep 2010 08:42
Usually if the ground wire is melted, that means something shorted. Have you checked all of the ground wires going back to the battery?
As far as the meter jumping around, do you have solid core wires with no-resistor plugs or caps? That can cause meters to go crazy.
Try an analog meter. They are not as susceptible to the RF noise.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- 2bskor
01 Sep 2010 09:17
Very good point. Took the resistor caps off when I did the coil mod and put new dyna coils on. I traced the ground wire back as far as the junction where all of the ground wires branch from and replaced the ground wire to the regulator with a new one. Everything from the junction on looks good.
- TeK9iNe
- What did you do!?!
01 Sep 2010 09:36
There is deffinately something to be said for new replacement parts. I've only had about 50% success with Fleabay and other used crap. It eith works just ok cause someone beat it good, then dies on you a year later, or just doesnt work right when you get it.
A new stator and new R/R unit with all new wiring is PRICELESS, works flawlessly, and pays for itself in the end.
Just save the dough, and buy new. It all works sooo much better than the old crap!
+ no headaches! :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- School Teacher
01 Sep 2010 19:29
checthe yellow leads with r/r unpluged they should be putting out 50v AC, then you can precede, have you ohm metered the r/r? to make sure it will pass if it was used?
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
- School Teacher
01 Sep 2010 19:33
TeK9iNe wrote:
If you can spring for it that is great! in fact if you are buying new get a stator off the G1 it is at least 50% larger from the factory, this was on the injected bike and they wanted to make sure the DFI was fed steady power.There is deffinately something to be said for new replacement parts. I've only had about 50% success with Fleabay and other used crap. It eith works just ok cause someone beat it good, then dies on you a year later, or just doesnt work right when you get it.
1980 kz1000G1
1980 kz1000G1
