How to check alternator output?
- thadley55
- TWO WEEKS!!!(Money Pit the movie)
30 Aug 2010 21:10 #395137
by thadley55
1975 XL125 Honda first bike
1993? VTR 250 Honda gone
1983 LTD 440 Yammy gone
1988 CBR 600 Honda gladly gone!!
1976 KZ900 daily driver
How to check alternator output? was created by thadley55
Hello!
I have a 76KZ900A4 I am having charging problems so I need to troubleshoot. I checked the voltage at the battery and it pretty much doesn't move as the revs go up. everything is stock. Much thanks!!
- PLUMMEN
- Thank you received: 104
30 Aug 2010 21:18 #395141
by PLUMMEN
Replied by PLUMMEN on topic How to check alternator output?
got a manual? it would take me 2 hours to type that one out for ya! :laugh:
- thadley55
30 Aug 2010 21:20 #395143
by thadley55
Replied by thadley55 on topic How to check alternator output?
I got a factory manual
- PLUMMEN
30 Aug 2010 21:22 #395144
by PLUMMEN
i think charging system is around pge 194 in the factory manual
- thadley55
30 Aug 2010 21:26 #395147
by thadley55
:dry: My manual only goes to 187
- thadley55
30 Aug 2010 21:34 #395149
by thadley55
I found it!!
Thanks!!
Thanks!!
- MFolks
- Thank you received: 540
30 Aug 2010 21:35 #395150
by MFolks
Replied by MFolks on topic How to check alternator output?
This should help:
Alternator Testing For the Older 4’s(Z1’s,Kz 900’s, Kz1000’s,Kz1100’s and GPz1100’s).
To check to see if the alternator is working you need to follow these simple steps:
1. Fully charge the battery as this will be the power source during this test.
2. Disconnect the Regulator/Rectifier at the plug that has the six wires in it.
3. Start the engine and let it warm to operating temperature.
4. If you're worried about overheating, position a large fan for cooling the engine.
5. After the engine has reached operating temperature, have a helper assist you, and using a multi-meter, read the output at the three yellow wires (or the alternator output wires)at the disconnected connector.
6. Raise the engine speed to 4000 rpm, and see what the three YELLOW wire combinations(or any alternator output wires) are(1-3, 2-3 & 1-2). The output will be around 50 Volts A.C.(Alternating Current). BE CAREFUL, AS THERE IS A SHOCK HAZARD HERE!!
7. If any of the combinations are low or non-existent, the stator(wire windings) are bad and must be replaced.
Some of the older Z1’s and KZ900’s were phase sensitive, so check the wire colors carefully.
8. Using an OHMETER, Check the three wire combinations again, looking for a reading of 0.36 - 0.54 OHMS. If the readings are above or below, the stator may be bad and need replacement. Also check from any of the three YELLOW wires to ground, this will show if arcing took place.
9. Before ordering a new stator, check the connections from the stator as there are electrical "Bullet" connectors that may be damaged or dirty.
Inspect the wiring for signs of shorting or overheating too. www.z1enterprises.com sells replacement rubber grommets for the alternator output wiring, they get hard and could leak oil after a while.
10. Check the wiring coming out of the grommet as there have been situations where the wires were damaged causing a short(I.E. twisted together with insulation damage).
11. The sprocket cover will have to be removed to access the electrical connectors coming from the alternator, the left foot peg assembly and shifting lever will have to come off also.
I wrote this as general guide for alternator testing, your particular bike may have a higher output than what I've listed.
- Old Man Rock
- Thank you received: 225
31 Aug 2010 20:09 #395280
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic How to check alternator output?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- thadley55
02 Sep 2010 21:18 - 02 Sep 2010 21:20 #395768
by thadley55
I'm a little confused MFolks, my 76 A4 has a separate reg/rec the white plug is for the rect. and has 3 yellow wires. The only plug that has all 6 wires has a black, white,green/red,black/yellow,brown,and blue/red. Should I disconnect this and check the VAC at the yellow wires or is this a test for only bikes with a combo reg/rec ?
One thing I should point out though is that I already perfomed a test on the rectifier and fount it to have no resistance that I could measure.
One more thing,should I go ahead and get the reg/rec combo?Is it hard to retrofit?
ThanksB)
P.S. I guess the reason I'm asking how to test my alternator is so I can fix this in one swoop instead of waiting for shipping twice
ThanksB)
Last edit: 02 Sep 2010 21:20 by thadley55. Reason: forgot something
- MFolks
02 Sep 2010 21:50 #395773
by MFolks
The earlier Z1's and Kz900's are wired differently than the bikes of the 80's with seperate regulators and rectifiers. Color codes on the wires are again diferent.
If it were me, I'd contact www.z1enterprises.com and order a combo reg/rect. A member here(Old Man Rock) recently had to replace his rectifier as it developed a short in one of the diodes on his bike.
I believe he used a combo unit with no problem.
