KZ 650 Dyna-S Upgrade
  • j3sst3r
  • j3sst3r's Avatar Topic Author
29 Aug 2010 04:33
#394691
Well, i must say that points are a pain! Still using stock coils on this bike, but have an option to buy the Dyna-S Ignition system for cheap. Wondered if the coils on there will work with it, or do i need Dyna DC1-1 coils specifically for this bike.
1978 KZ650 SR
  • loudhvx
  • loudhvx's Avatar
Re: KZ 650 Dyna-S Upgrade
29 Aug 2010 04:44
#394692
The stock 4-ohm coils will work, but if they are old, you may want to eventually get the Dyna or Accel 3-ohm coils for use with the Dyna S.
  • 55fbomb
  • 55fbomb's Avatar
29 Aug 2010 04:45
#394693
I dont know for sure about the KZs but on my Honda you can use the stock coils with one and they dont want you to use anything hotter 3 ohm.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
  • Old Man Rock
  • Old Man Rock's Avatar
29 Aug 2010 07:02
#394719
As Loud mentioned should work if they are indeed the OEM coils (resistance)...
Same time, do yourself & beloved KZ a huge favor...
Replace with matching Dyna coils and plug wire set as well and feel the difference... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
