78 KZ650 Sr Handle Bar Upgrade
  • j3sst3r
  • j3sst3r's Avatar Topic Author
26 Aug 2010 10:02
#393942
Hey everyone. I bought a pair of straight bars for this bike and had a couple questions. This pair didn't come with any drilled holes for the control wiring and lines for the bike.
Do you know of anywhere online i could purchase a chrome set that will match up with this bike, has pre-drilled or cut holes, and fit these controls? Not sure of bar schematics. I've seen them on pictures for these Old Kz's.
Thanks for any replies. Glady appreciate the help... Some of this stuff is hard to find.
1978 KZ650 SR
  • otakar
  • otakar's Avatar
Re: 78 KZ650 Sr Handle Bar Upgrade
26 Aug 2010 11:15
#393963
The cables are run on the outside on the newer bikes. You will most likely have to get a new a (shorter) clutch cable also. If you keep the original length clutch cable it might bind on you.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
