Putting 82gpz1100 coil on 1978 Z1R
  • flhwesty
  • flhwesty's Avatar Topic Author
25 Aug 2010 17:19
#393813
putting gpz 1100 coils on a 78 z1r,does the wires coming from the points go to the negative sides of the coils?
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
  • steell
  • steell's Avatar
Re: Putting 82gpz1100 coil on 1978 Z1R
25 Aug 2010 17:48 - 25 Aug 2010 17:57
#393828
They can if you want, although it makes absolutely no difference.
You may want to check the primary resistance on those coils if you're connecting them to points. The GPz1100 has electronic ignition. You need coils with at least 4 ohm primary resistance, or a ballast resister, if you have points.
Last edit: 25 Aug 2010 17:57 by steell.
  • flhwesty
25 Aug 2010 18:29
#393842
What i really need to know does the wires coming from the points go to the negative sides of the coils?
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
  • Saki Jockey
  • Saki Jockey's Avatar
25 Aug 2010 19:37
#393860
Yes.
Rob A.
550 A4
GTA,
Ontario, Canada
  • otakar
  • otakar's Avatar
25 Aug 2010 19:37
#393861
The 78 Z1R used a 3 Ohm system. The Gpz1100 had a 2.2 Ohm system. If you run the GPZ coils with the ballast resistor you will have a very small spark. If you run them without the resistor you will arc out your points.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • flhwesty
26 Aug 2010 13:11
#393993
Ok Thanks for the advise. A friend of mine needed one coil, for his restoration project Z1R, and I offered my OEM coils to him. He gave them back and will find another. Again thanks for responces.
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
