RR replacement w GSXR RR
  • Mark Whiddon
  • Mark Whiddon's Avatar Topic Author
24 Aug 2010 17:23 - 24 Aug 2010 17:25
#393566
I have a chopped (no where near stock) 1980 KZ750 have just replaced the stator and RR with new units and "seems" to be doing ok. The RR is a 5 pin connecter with a bullet wire for charging. 3 yell=stator 1 black=grnd 1 brn=voltage sensing (I believe) one red/wht= charging pos. It gets relitively hot(I know it is supposed to) just wondering about using a 5 wire GSXR 1000 RR if I need a replacement in the future. I have been doing alot of reading on this but cannot find anything that relates specifically to my bike. The GSXR RR is supposed to run cooler and be an all around better unit than most RR. It has 3 stator wires plus 1 grnd and 1 poss. I am thinking it would be sensing the voltage going into the batt and that is how it works rather than a seperate sensing wire like my current RR. Any thoughts would be greatly appreciated.
Mark
Last edit: 24 Aug 2010 17:25 by Mark Whiddon.
  • MFolks
  • MFolks's Avatar
Re: RR replacement w GSXR RR
24 Aug 2010 19:50
#393624
Ask over at www.wgcarbs.com as George is good at figuring out electrical systems.
  • steell
  • steell's Avatar
24 Aug 2010 20:22
#393629
The GSXR reg/rec can't run any cooler than yours does because it will still be dumping the same amount of current as heat.
  • Mark Whiddon
24 Aug 2010 21:25
#393640
I will agree it must dump the same amount of current, however if the GSXR RR is made with more efficient cooling fins, or larger amount of metal to conduct it away, it would stand to reason that it would stay cooler. however slight that may be. I am only going off of posts that I have read. Mostly on the CBR forum using the gxsr on a cbr and it working much more efficeintly and cooler, so I thought I would post the question concerning my 1980 KZ750. Keep the comments coming please.
Mark
  • School Teacher
  • School Teacher's Avatar
25 Aug 2010 10:02 - 25 Aug 2010 10:03
#393730
from what i have read the pos of the gsxr would be like your red/white wire and it should work.
im replacing one right now but it is 1 phase.
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Last edit: 25 Aug 2010 10:03 by School Teacher.
