kz 650 sr regulator rectifier- I don't own any 650
- School Teacher
23 Aug 2010 16:48
HI guys working on the above bike and was wondering the specs to check the rectifier, i only have a book that is for the 3 phase and this is a single phase, the alternator leads are puting out 76 v ac, but at 4000 rpm i get very little difference in battery voltage.
got any specs or help fire away
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
- School Teacher
Re: kz 650 sr regulator rectifier- I don't own any 650
23 Aug 2010 17:16 - 23 Aug 2010 17:17
1980 kz1000G1
1980 kz1000G1
Last edit: 23 Aug 2010 17:17 by School Teacher.
- TeK9iNe
- What did you do!?!
23 Aug 2010 18:42
Very little difference, as in no increase or decrease?
Best way to test is to swap out with known good unit, but that isnt always easy.
The only thing controlling the voltage/current output of the alternater, is the R/R unit, therefore... its toast, or batt is toast.
Is batt known good batt? New is best.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- School Teacher
23 Aug 2010 19:09
batt seems good it starts the bike up no problem, when i checked the resistance one way i got resistence then checked it the oppisite on the same two leads i get open circut. well i am in oregon any one got a known good 1 phase rectifier i can swap out?
1980 kz1000G1
1980 kz1000G1
- j3sst3r
26 Aug 2010 10:15 - 26 Aug 2010 10:16
My bike had a similar issue. I own a 1978 KZ650 SR. We tested the battery and turned out good. The rectifier was bad and needing replaced. However, i found a website that makes these bad boys NEW! Ordered one for about $98 dollars. They cover a large amount of old KZ's. Here ya go brother:
www.oregonmotorcycleparts.com/Products.html
1978 KZ650 SR
Last edit: 26 Aug 2010 10:16 by j3sst3r.
