Coil?
- ssschultz
Coil?
23 Aug 2010 15:04
Okay so I figured out what this bike is. I got a key for it but to get it to run I think that I still need a coil. Is that what this is? I really don't know a whole lot about motorcycles but I'm trying to teach myself as I have been riding since I was 16. I'm sure I will have lots of stupid questions.
1980 KZ 250 LTD
- ssschultz
Re: Coil?
23 Aug 2010 15:07
This is the part that is broken. I went to pull the cover off the spark plug and the cable just fell apart. Can I use another kind of coil or do I have to get one of these?
1980 KZ 250 LTD
Re: Coil?
23 Aug 2010 15:33
ssschultz wrote:
Can't tell from the photo what exactly is broken.
Plug cap pulled off plug wire???
Would put 1980 KZ250 LTD in your signature.
And it's easy to do. Here's how:
Click > kzrider.com/index.php?option=com_kunena&...ew&catid=8&id=382004
- ssschultz
Re: Coil?
23 Aug 2010 16:15
Yes it was the cap that pulled off the wire. That is just what the wire went up into.
1980 KZ 250 LTD
- otakar
Re: Coil?
23 Aug 2010 16:19
Snip off about 1/4" of the end of the wire and SCREW the cap back on.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- timebomb33
Re: Coil?
23 Aug 2010 16:20
if the cap just came off not a big problem cut the cable back about a 1/4" or so and just thread it back onto the fresh end of the cable these caps have a threaded point up inside the end of it for just this very reason and if you want to change the cap sometime just unscrew it.
I THINK MY POWERBAND BROKE
- ssschultz
Re: Coil?
23 Aug 2010 16:23
Thanks guys I will give it a try when I get home from work. Hopefully that should let me get it started.
1980 KZ 250 LTD
