Tachometer
  • arizcoin
  • arizcoin's Avatar Topic Author
Tachometer
20 Aug 2010 11:28
#392511
When I am coming off throttle sometmes I have a vibration in my tach. It seems that the tachometer is lagging behind
engine rpm. Is that something I can repair?
Re: Tachometer
20 Aug 2010 11:30
#392512
Have you cleaned and lubed or replaced the cable?
  • arizcoin
Re: Tachometer
20 Aug 2010 11:43
#392518
No any instruction on doing so?
Re: Tachometer
20 Aug 2010 11:48
#392519
I would just remove the cable (each end unscrews) pull out the center cable from the sheathing (you'll see what I mean with the cable off the bike), wipe it clean with motor oil, put a fairly thin coat of motor oil on it after it's clean, and re-install. It may fix the problem. If the inner cable is frayed or rough, or if the ends are damaged, you may want to replace it. Ed
  • arizcoin
Re: Tachometer
20 Aug 2010 13:07
#392533
Thanks Ed
