Converting to Push-To-Cancel switch?
- Toonces
18 Aug 2010 10:25 - 18 Aug 2010 21:07
I want to fit a "Push to cancel" type switch cluster on the left side of my KZ650. The switch housing that I have now is metal. I'm pretty sure I might have good luck with fitting the switch from a ZG1000 but it has a non-metallic housing and I?d like to use a metal one so that it sort of matches my right side switch housing. So my question is, does anyone know of a Kawasaki that has "Push to Cancel" blinker switch with a metal housing?
Last edit: 18 Aug 2010 21:07 by Toonces.
- jjdwoodman
- Live free, or die.
Re: Converting to Push-To-Cancel switch?
19 Aug 2010 19:23
Not with the metal housing. I think they all went to black abs before any canceling switches.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
81 550 Mostly there
83 ZN1300 Voyager
- Toonces
19 Aug 2010 19:49
Sorry to say but I'm thinking you're right about that.
Thanks for the reply.
- Motor Head
19 Aug 2010 19:58
Well I'm not sure if my info will help.
On my 2 82's they have self canceling turn signals, 1 actually works. Both have the metal switch housings. With that said they both also have a front wheel speed sensor, a electronic speedo and separate Odometer, this is where the distance is calculated to operate a solenoid in the turn signal switch housing pushing the switch to neutral. So with out the rest of the system the switch with metal housing probably wouldn't help.
