Ignition switch kz900
- nads.com
16 Aug 2010 13:32
Is got a knew switch and it has 6 wires. I think the old one had four. Is there any difference between the to? It's been over 10 years since I took the old one out and I think it had only four wires.:blink:
- Jeff.Saunders
Re: Ignition switch kz900
16 Aug 2010 13:42
Kawasaki evolved the design of the switch as production switched from the 900's to the 1000's. The 6-pin switched work with the older 4-pin harnesses and the newer 6-pin harnesses.
www.z1enterprises.com
Z1 Ent on Facebook,
- Jeff.Saunders
16 Aug 2010 13:43
only when you get to 1980 are there issues as Kawasaki implemented an additional brown wire coming out of the switch on 650 and 1000 models. On those models some wiring adaptation is needed.
Z1 Ent on Facebook,
- Old Man Rock
16 Aug 2010 14:05
Nads...
Just went through this myself... Plug & Play... The KZ900 harness (4 conductor) keyed plugs into the ignition switch 6 conductor connector.
Ignition switch conductors 5 & 6 are not used in the 900. Conductors 1-4 are the same color code as the KZ900 harness conductor colors...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
