LED gauges
  • Omaha Rider
  • Omaha Rider's Avatar Topic Author
LED gauges
15 Aug 2010 21:22
#391170
Does anyone know if I can replace the gauge light bulbs with LED light bulbs? If so, where can I find them?
Thanks
BTW, on a 78 KZ650
1978 KZ650 SR D
  • otakar
  • otakar's Avatar
Re: LED gauges
15 Aug 2010 21:43 - 15 Aug 2010 21:44
#391174
Yes and here. I do not have a single incandescent bulb on my bike. They are ALL LED with the exception of my headlight which is HID.
www.superbrightleds.com/cgi-bin/store/in...&Page2Disp=/1157.htm
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 15 Aug 2010 21:44 by otakar.
  • Omaha Rider
Re: LED gauges
15 Aug 2010 22:02
#391181
Sweet! What kind of istrument bulb would I need? Neowedge? B8 series? BAX series? B10D series? T1.5 series?
1978 KZ650 SR D
  • otakar
  • otakar's Avatar
Re: LED gauges
15 Aug 2010 22:27
#391190
You would have to take one out of your bike and match it. i have no idea what you have in there.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Omaha Rider
Re: LED gauges
16 Aug 2010 07:22
#391239
Do I have to take off the headlight to take apart the gauges?
1978 KZ650 SR D
  • PLUMMEN
  • PLUMMEN's Avatar
Re: LED gauges
16 Aug 2010 07:27
#391241
would probably make it easier
  • Omaha Rider
Re: LED gauges
16 Aug 2010 07:56
#391247
Damnit, it seems tough to do. There are two bigass bolts to take out and the headlamp flexes when I try. BTW i'm in West Omaha near 156th & Dodge.
1978 KZ650 SR D
  • neil1492
  • neil1492's Avatar
Re: LED gauges
17 Aug 2010 20:07 - 17 Aug 2010 20:14
#391777
You can replace the indicator bulbs by unscrewing the plastic piece around the ignition key. To remove the headlight you need to unscrew two screws around the outside of the headlight. After that you can undo the two bolts on the sides. I am not sure how to get to the speedo and tach bulbs...if there are any in there mine don't work.
My 1980 uses a bulb 53 for the dash lights. You might want to check yours first.
1980 KZ650 LTD
Last edit: 17 Aug 2010 20:14 by neil1492.
  • wlabrum
  • wlabrum's Avatar
Re: LED gauges
26 Aug 2010 13:45
#393999
I attend iwcc i could stop by after school (1 pm ish) and lend ya a hand if ya need it. let me know
Bill
If it ain't a liter its just a mini bike
