kz750 ltd h2 1981 self cancel signal relay unit
- angel_uk
- Wildlife Artist and adventurer by any means!
Re: kz750 ltd h2 1981 self cancel signal relay unit
08 Aug 2010 14:00
hi
many thanks for taking your photos. i can't make out the actual part. the self cancel unit is like a 3" x 4" rectangle with two lots of wires coming out of it.
- KAHruzer
08 Aug 2010 17:58 - 08 Aug 2010 18:02
OK, another try here, there's a body at stake.
The image below (hopefully, this time) shows the bracket as part number 11034B below, but does not indicate how/where it attaches.
I went out and looked at mine. So far as I can tell, it doesn't have one. Any chance this was optional? Or, discontinued after 1981? The part does list for H2-H4, however.
Kind of looks like it could attach to part 11034A, but that would place it on the left side of the battery box.
And, 11036A looks to be an alternate part, replacing 11034A, perhaps just for this purpose, as an option.
KZ750-H4 LTD 1983 Project
KZ400-B2 1979
KZ400-B2 1979
Last edit: 08 Aug 2010 18:02 by KAHruzer.
- Motor Head
08 Aug 2010 18:01
I think you have to start out having a "Distance" sensor, for me that has been on my front wheel and an electric speedo.
- KAHruzer
08 Aug 2010 18:09
Motor Head wrote:
The Distance Sensor for KZ750-H2 through H4 is stated in the manual to be inside the headlight housing.
KZ400-B2 1979
KZ400-B2 1979
- Motor Head
08 Aug 2010 18:23
OK so then if this is there than they also put in the self cancel,right? And later switched to and electronic speedo, and Odometer on some models.
- Link14
08 Aug 2010 18:57 - 08 Aug 2010 19:01
Hi Angel,
I've (almost)got the same bike that you have- mine's an '82. Just went out and shot this pic. It's been a couple of years since I took the bike down and cleaned everything up, but I seem to remember that this is screwed into a bracket that bolts onto the battery box.
If you need more than that, let me know. I can remove it in a couple of days and get a clearer pic, but right now my garage is so full of my daughter's stuff, I could barely get this picture. She moves back to the university this week so I'll have more room then.
My bike's self-canceler doesn't work, but I think it's due to something in the turn signal switch....it's never been right since I cleaned it. The bike runs great though, so I'm not too worried about using it manually and need to spend more time (and money) on the 900.
Hope this helps
Link
Hope this helps
Link
Last edit: 08 Aug 2010 19:01 by Link14. Reason: wrong year on bike
- angel_uk
09 Aug 2010 01:30
hi link and all the other kz'r!
what a star you're!
Thank you so much for helping me with this.
I've been asking around for 1 year and even asked kawasaki!
They weren't interested and said 'buy a newer bike!'
thanks again to everyone!
regards
angie
what a star you're!
regards
angie
- djturnz
22 Sep 2010 04:06
Mine looks just like the 82 model that LINK14 posted. I found it when I was trying to change my flasher relay. Does anyone know what the connector to the right and a bit lower than the Self Canceler is hooked to? Mine was unplugged last night, yet everything has seemed to be working fine.
1982 KZ750 (4) LTD
- angel_uk
22 Sep 2010 09:00
hi dj
what are the colours of the wires please?
is it the white plug with 3 wires connected?
best wishes
angie
ps i've just rewired my bike, fresh harness etc!..
:laugh:
best wishes
angie
:laugh:
- djturnz
23 Sep 2010 04:05
In the picture posted, it is the smaller white connector on the right that is oriented mostly vertically. When I pulled my side cover off, it was unplugged, and apparently, I have been riding like that.
1982 KZ750 (4) LTD
- angel_uk
23 Sep 2010 04:53
hi dj
my bike is a kaw kz750 ltd h2 1981.
my white three pin connector has three wires:-
green & white
black & yellow
blue
please see the coloured wiring diagram that i've uploaded for the kz riders/builders on the forum.
the 3 pin plug is for:-
the brake light failure indicator switch, so it's for your safety buddy!
best wishes and ride safe
angel from the uk!
green & white
black & yellow
blue
angel from the uk!
- djturnz
24 Sep 2010 04:04
Well I guess its a good thing my brake light hasn't failed. Thanks
1982 KZ750 (4) LTD
