Replacement fork turn signals for '81 750LTD
  • jonnygorman
  • jonnygorman's Avatar Topic Author
03 Aug 2010 14:32
#387931
I changed out my mini ape hangers for a superbike bar and now there is no space for my front turn signals. I am trying to find something that will mount on the upper part of my forks as opposed to handle bars. Any ideas? or avenues?
Thanks
Jon
  • Motor Head
  • Motor Head's Avatar
Re: Replacement fork turn signals for '81 750LTD
03 Aug 2010 16:05
#387954
Head light bucket mounting bracket, long stem signals are real common. But maybe you want something more custom. The EBAY is full of used stuff.
  • JMKZHI
  • JMKZHI's Avatar
03 Aug 2010 16:52
#387967
You could install turn signals stems in place of the big headlite bolts - they're usually the same size.
Here's a topic w photos.... turn signal stem? .
  • dwlk5
  • dwlk5's Avatar
06 Aug 2010 07:28 - 06 Aug 2010 07:29
#388616
You could put them here like this. but use a longer stem because like this they cant be seen from oncoming traffic. I plan on changeing these. maybe i could put them on the head light.
Last edit: 06 Aug 2010 07:29 by dwlk5.
  • MFolks
  • MFolks's Avatar
06 Aug 2010 08:29
#388623
If not E-Bay, look at these: www.kandstech.com/
