1981 KZ 650csr starter clutch issue
  • Dwayne22
  • Dwayne22's Avatar Topic Author
31 Jul 2010 09:08
#387228
I've had this bike for about 3 months, has been cold hearted all along, progressivly became more difficult to start. Had carbs cleaned, spark plugs replaced and gapped properly. Now it seems when the motor fires once that the starter kicks out and makes a loud grinding noise. I removed the starter and reached in and found that the cog that the starter turns has a good bit of play, turns only counter clock wise. This leads me to believe that the starter clutch is not functioning proprerly. Question is are there any adjustments that may help extend the life of the existing starter clutch? If anyone has infommation about where I can find diagram of the starter clutch or instructions on replacement, I'd appreciate it,
  • drmadd95
  • drmadd95's Avatar
Re: 1981 KZ 650csr starter clutch issue
31 Jul 2010 19:23 - 31 Jul 2010 19:24
#387329
Hey, I'm in the process of replacing a starter clutch in a kz750 myself. Anyway. The gear only turns freely the one direction and it is a little loose side. I'm sure what's happening is that the clutch isn't dis-engaging after the motor starts up and this is causing your sound. (I'm sure someone will correct me if I'm wrong. :) ).
As far as extending the life of the clutch you may want to take it apart and replace the springs and rollers in it. Unfortunately for me mine was shot beyond repair and I needed to replace mine. I couldn't even turn my motor over it was that bad.
Here's a post related to how the clutch works: kzrider.com/index.php?option=com_kunena&...d=2&id=386246#386252
Here's a PDF file for taking out the starter clutch (Someone else made this file and I found it on the forum so I take no credit for it what so ever):: kzrider.com/index.php?option=com_docman&...d&gid=389&Itemid=108
Welcome to the forum!
1979 KZ650 B (Main Ride)
1978 KZ650 D1 (sold)
1982 KZ750 (parts bike)
Last edit: 31 Jul 2010 19:24 by drmadd95.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
31 Jul 2010 19:39
#387335
This post over at 650info has a wright up on the starter clutch, gotta log in to get the download though.
forums.kz650.info/index.php?topic=2482.0
Welcome, both of you.
B)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Dwayne22
01 Aug 2010 11:45
#387435
Thank you for the info and links.... the PDF file will come in handy..... This seems like a place for reliable info, I'm grateful that I came across it!
