76 speedometer on 80 kz750?
  • yungkzrider
  • yungkzrider's Avatar Topic Author
30 Jul 2010 19:01
#387116
I've got a 1980 kz750 e-1 that has an 85 mph speedometer. I'm wanting a 75 or 76 speedometer which goes to 130 or 140 mph.
The question is, is the cable the same going from the gear on the wheel to the speedometer? And will I have to also get the wheel gear off of the 75 or 76 kz for the speed to be accurate or will mine work and not be off?
Thanks for any information!
Re: 76 speedometer on 80 kz750?
30 Jul 2010 20:00
#387130
Can't recall off-hand the earlier thread topic on this subject, but do recall that the 85 mph speedometer could be replaced with a similar 130+ version, and would be accurate without any change to the speedometer drive at the front axle.
In other words, may keep using the same speedo drive at the front axle.
is the cable the same going from the gear on the wheel to the speedometer? YES
will I have to also get the wheel gear off of the 75 or 76 kz for the speed to be accurate -- NO
YES, it will work and it will not be off.
Let us know if you have difficulty locating the earlier thread via the search function.
Good Fortune! :)
30 Jul 2010 20:02
#387131
Hello, Nik, and WELCOME to KZR forum! :)
We're glad you're here! :cheer:
  • yungkzrider
30 Jul 2010 21:15
#387138
Well I did search lol don't worry I'm familiar with forums. My other hobbies are my ford crown Vic and Toyota supra turbo SO I do search don't worry!
I found the thread where someone was switching a speedo on an 83 ksr1300? For a 160 mph unit but figured this was too different.
Thanks for the replies!
31 Jul 2010 02:20
#387165
Click > kzrider.com/index.php?option=com_kunena&...limitstart=40#367510
Good Fortune! :)
