tachometer oil seal
  • Lazyman06
  • Lazyman06's Avatar Topic Author
tachometer oil seal
30 Jul 2010 16:48
#387077
How difficult is the tachometer oil seal top change out? About to order a bunch of stuff and wanted to get this little fire put out.
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
  • Skyman
  • Skyman's Avatar
Re: tachometer oil seal
30 Jul 2010 17:00
#387079
Very easy.
West Linn, OR
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
30 Jul 2010 17:13
#387084
The tach drive assembly is held into the head with a single bolt. While you don't have to remove it from the head, it's usually easier to do it this way.
Get the 10mm o-ring that goes around the outside of the drive as they often will leak as well as the tach seal.
30 Jul 2010 17:50 - 30 Jul 2010 17:51
#387088
When removing the old seal, be sure to get out all its cremains, which may be baked, encrusted and carbonized (maybe even petrified) in its position.
The seal is a small circular rubber ring affair with a tiny coiled spring around it.
A dental pick or similar tool is handy to scratch out the remains.
Click > Z1E Hook and Pick Set
A good light and magnifying glass is also helpful.
Good Fortune! :)
Last edit: 30 Jul 2010 17:51 by Patton.
30 Jul 2010 18:01
#387091
When new tach seal and 0-ring are properly installed, there will no oil leakage whatever from inside the valve cover through the tach drive, even without connecting the tach cable.
Could ride cross-country without a tach cable, and without any oil leakage from the tach drive.
People are wrong when thinking the tach cable must be tightly fitted to the tach drive in order to prevent oil seepage from the tach drive area. This may "catch" the oil seepage and collect it inside the tach cable, but does not "repair" the leaking tach drive (which isn't supposed to be leaking in the first place).
Good Fortune! :)
  • MFolks
  • MFolks's Avatar
30 Jul 2010 18:06
#387093
The worst case situation is when seals fail and oil is pumped up the tach cable, possible dripping out or getting into the instrument itself.
