Turn signal problem and now no ignition - wtf?
- stonemaster
Re: Turn signal problem and now no ignition - wtf?
28 Jul 2010 16:06
ground wire issue, easy enough, check all grounds
- alexnelson
28 Jul 2010 17:57
stonemaster wrote:
You make it sound so simple . . .
78 KZ650-D1
K&N pods + 4-1 Pipe
Mikuni VM24 - 7.5/115/#4 Clip
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
- alexnelson
28 Jul 2010 18:37 - 28 Jul 2010 20:11
Annnnnd we're back.
Dirty connections on the engine kill switch.
I feel so good right now.
EDIT: False Alarm. Fuses keeps blowing. At least I figured out where I was losing power to the rest of the bike. Now I just have this persistent blown 20A fuse problem.
78 KZ650-D1
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
Last edit: 28 Jul 2010 20:11 by alexnelson.
- MFolks
28 Jul 2010 18:40
Print this out, as it's a good electrical troubleshooting procedure:
The Dreaded Shorting/Intermittent Electrical Problem!
Here is the most basic method I know(Taken from www.kzrider.com by member Patton)
1. Charge your battery and have it load tested if you can. The floating ball hydrometer can be used to check the specific gravity of the charged cells in the battery.
2. Disconnect the Black lead from the (-) Battery terminal... or Red from the (+) Battery terminal, it does not matter which one.
3. Connect one of the following test setups in series with the Battery terminal and lead:
3.1 A 12 V light bulb,
3.2 A 12 V test light,
3.3 A 12 V test buzzer or,
3.4 A 12 V horn... you get the idea.
4. With the Ignition Switch OFF, go through your harness and wiggle the wires while looking/listening for the test setup to go on/start buzzing.
5.With the Ignition Switch ON, repeat the test except this time the looking/listening for the test setup to go off/stop buzzing.
6. Be prepared to open the Ignition switch and check/test for solder joint failure and or circuit board micro breaks (don't ask how I know this ).
7. Be prepared to pull the wires out of the Head Light to test for failures at or near the grommet.
8. Be prepared to open the harness at or near the Steering Neck for failures. This is where wires tend to exhibit fatigue due to repetitive movement.
9. Be prepared to open the left and right switch gear to search for rust and or broken parts. CAUTION: watch out for flying springs, ball bearings and stuff. Do indoors on White sheet (again don't ask ).
10. Be prepared to follow the heavy gauge wire from the Starter Solenoid (Relay) to the starter for bare wire exposure. Especially near bends and grommets.
11. If you can reproduce the fault symptom your are pretty much home free. Be prepare to find and repair/replace any internal wire breaks, insulation break downs, exposed wires, rubber grommet failures, etc. Often, shrink tubing will solve the problem temporarily until something better can be done.
12. I use a very good electrical contact cleaner/preservative called De-oxit made by Caig Labs in San Diego Ca. Their website is www.deoxit.com It can be purchased at Radio Shack and any other electronic supply store. I use it on all of my motorcycle’s electrical connectors , in my home entertainment center’s stereo patch cords and cordless phones charging cradles.
- alexnelson
28 Jul 2010 20:09 - 28 Jul 2010 20:15
Thanks. I'll be sure to go through this when I get a 12 V buzzer or light or something.
After taking a ride for a block the 20A main went again. Could this be a reg/rec problem?
What happens is I ride for a block, come to a stop sign, and the 20A main fuse blows as soon as I rev it into 1st gear.
78 KZ650-D1
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
Last edit: 28 Jul 2010 20:15 by alexnelson.
- MFolks
28 Jul 2010 20:55
Could be a wire or more rubbing through the insulation when the handle bars are turned.I'd get the buzzer or test light connected and prepare to spend some time figuring out where the problem(s) is/are.
- Old Man Rock
29 Jul 2010 05:32 - 29 Jul 2010 12:51
Other than a electrical short to frame during a ride...
Good (ideal) battery to frame/engine ground?
Does the 20AMP (stop using the 30amp :whistle:) fuse blow in a non ride?
BTW, in an emergency as you did, I'd do the same so don;t take it personally....
Aim a cooling fan on the engine, start and warm it up a couple minutes as normal... rev it and hold to 3-4K, fuse blow.... Twist the throttle up to ~ 5K, don't hold, fuse blow....
Remove the tank and get yourself some longer fuel line... Start the engine, leave at idle and jiggle the electrical harness, tap the bar controls/switches... Fuse blow?
If no problems in above....
Rectifier/regulator most likely cause of fuse blowing during a ride where a rectifier diode is shorting to ground or one of the regulator SCR's is doing the same...
Could be through current/heat break downs, reverse voltage breakdowns, age of electrical components etc....
Have you gone through the OEM electrical test and measurements... If not, good time to do so....
Also, clean all your connector pins and inline bullet connections with Emory cloth.... You don't have to grind down metal, just clean the oxidization off them pins.... You may be surprised in the out come....
OMR
EDIT: BTW, don't rely on buzzers, 12Vdc lamps etc... for they will activate in non true 12Vdc.... Sure, they're ok just to see if current is flowing or not but at what voltage is the question....
Get your self a meter, preferably with diode measurement capabilities this way you can check your rectifier diodes as well....
Only way to go and you can pick a fairly decent one up @ $20-$40....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 29 Jul 2010 12:51 by Old Man Rock.
- alexnelson
29 Jul 2010 12:46
Going through and cleaning all connections now with deoxidizer and cloth.
Noticing burn marks on black/yellow wire (ground?) coming out of the regulator/rectifier. This is the ground wire for most of the lights on the bike no?
78 KZ650-D1
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
- Kawickrice
29 Jul 2010 12:50
alexnelson wrote:
Check for a short where the switchpod mates to the handlebars. That would explain why it pops when you roll the throttle
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- polkat
29 Jul 2010 14:12 - 29 Jul 2010 14:12
The black/yellow wire is wire from the reg to ground. Most of the bikes ground wiring is blk/yel. If the regulator/rectifier is shorted inside and is shunting the stators output to ground through that wire, it could be enough to fry it. Sounds like a bad reg to me.
Last edit: 29 Jul 2010 14:12 by polkat.
- alexnelson
29 Jul 2010 14:51
Kawickrice wrote:
I couldn't see anything too suspect in there. Besides, it doesn't blow when I roll the throttle while in neutral. Only when engaging first gear and then rolling the throttle.
78 KZ650-D1
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
- alexnelson
29 Jul 2010 14:55
polkat wrote:
I'm starting to think this too. Would this explain why the fuse only seems be blowing after a block of riding? The stator gets enough of a charge to the rectifier but because it's not working properly a fuse goes?
78 KZ650-D1
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
