Headlight for City
  • yourebarred
  • yourebarred's Avatar Topic Author
Headlight for City
27 Jul 2010 08:51
#386218
I understand that in the US you require a day riding light? I know you do in some parts of Europe. Anyway I have a z650 CSR in the UK where we don't need a day riding light. I wonder if it affects my economy enough to change it?
If anyone thought it did, how would I go about rewiring it so it only goes on when I switch it, or is that a rhetorical question?!
Thanks guys
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Headlight for City
27 Jul 2010 08:53
#386219
Just leave it on, its not going to affect anything, and it makes you more visible.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Capt America
  • Capt America's Avatar
  • Born Bad
27 Jul 2010 10:04
#386239
After years of day running lights being enforced on motorcycles made after 1969 in Canada. I've found that people have become even blinder than they once were.
Now they don't even seem to see a vehicle coming at them if they don't spot the lights they've been trained to look for, a sad state of affairs imo.
At any rate, tis your life, a simple toggle switch on the headlight negative line will do what you want.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
27 Jul 2010 11:20 - 27 Jul 2010 11:25
#386256
No eBay APP ID and/or Cert ID defined in Kunena configurationSome of the modulating motorcycle headlights seem really good at attracting attention of oncoming motorists.
Am guessing it's an aftermarket unit that fits inside the headlight shell. And continuously flashes between high beam and low beam.
Have mostly seen them used on larger bikes such as Harleys, BMWs and Gold Wings, but would likely fit any model.
At first I thought it looked irritating, then re-thought to that's exactly what's needed. B)
Here's one of several listed on ebay.
Good Fortune! :)
Last edit: 27 Jul 2010 11:25 by Patton.
  • bountyhunter
  • bountyhunter's Avatar
27 Jul 2010 11:23
#386258
That's why the law now allows us to use a headlight modulator which makes the light extremely visible, some would say insufferably annoying....
  • bountyhunter
27 Jul 2010 11:28 - 27 Jul 2010 11:29
#386259
I believe what they use is a circuit which modulates the single filament (either high or low beam) from 100% intensity to 30% intensity using a pulse width modulator circuit at a rate of 4 Hz.
Last edit: 27 Jul 2010 11:29 by bountyhunter.
  • yourebarred
27 Jul 2010 11:39
#386268
I agree folk see you better, though they also pull up and tell you it is on!
So no noticeable difference to fuel economy you reckon?
  • MFolks
  • MFolks's Avatar
27 Jul 2010 14:59
#386338
Probably hard to measure regarding gas economy except in labratory conditions.
  • bountyhunter
27 Jul 2010 21:59 - 27 Jul 2010 22:00
#386442
It actually uses less power because the light is pulsed between being full on and 30% on, average power used is lower than just running the light.
As for running a headlight compared to being off all the time: it's about 50W which is about 0.07 horsepower. I can't believe that added power is going to have a measurable effect on fuel mileage.
Last edit: 27 Jul 2010 22:00 by bountyhunter.
