Broken battery post!?
  • polkat
  • polkat's Avatar Topic Author
25 Jul 2010 15:24
#385641
My new battery (12 AA) snapped off the positive battery post when I stupidly used a bolt that was a bit too long. Dang! It's a good battery too.
Well, in the past I have drilled the bigger posts in car batteries down the center, and screwed in a stud. But the terminals on these bike batteries are flat, and small! Don't see doing the stud thing as the lead doesn't go deep enough into the case.
Any ideas for a fix, or is it now junk?
  • Motor Head
  • Motor Head's Avatar
Re: Broken battery post!?
25 Jul 2010 15:26
#385643
If you supply a Pic someone around here may have an Idea?
  • TerryK
  • TerryK's Avatar
25 Jul 2010 17:10
#385729
I've soldered them back on before. Just use non-flux solder and a mid sized iron (obviously not a torch lol) ,work slowly and it will be strong enough if you are careful when tightening the bolt.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • polkat
25 Jul 2010 21:48
#385793
Well, my camera's battery is dead, but here's a quick drawing of the positive post. The drawing is a bit exagerated, but you'll get the idea..............
  • polkat
25 Jul 2010 21:50
#385796
Well, my old camera has a dead battery, but here's a quick drawing. The crack is a bit exggerated here, but you'll get the idea.............
  • loudhvx
  • loudhvx's Avatar
25 Jul 2010 22:35
#385813
Get a pure copper bolt and nut. Cut the head off the bolt. Straighten up the threads on the bolt where it was cut so the nut screws on easy. Clean bolt and nut and terminal with a brass brush. Then clean with acid flux. Put copper stud into terminal with copper nut in place of original battery nut. Screw in stud flush with nut. Put stainless nut on front side of stud to keep solder off of threads. Then solder the whole works, but try to keep the threads of the stud clean. If you're good or lucky, the stainless nut should come off and you'll have a battery post with a stud.
I've never done this, and there are several problems I can see. I'd really like some opinions on the likelihood of this working before you try it.
Hopefully someone can come up with something simpler.
  • polkat
26 Jul 2010 01:23 - 26 Jul 2010 01:26
#385842
It's not a bad idea. I used to solder copper water pipe with a smaller propane torch in one of my past jobs. Is this the kind of soldering gear/heat we are talking about? And I suppose watching out for melting the plastic case is necessary?
Last edit: 26 Jul 2010 01:26 by polkat.
  • loudhvx
  • loudhvx's Avatar
26 Jul 2010 14:26
#385995
Yeah, not really usre how to do it. Plastic will want to melt first and it will be a mess. I think this idea won't work. Any heat source to heat the terminal will melt the plastic too, even with adequate shielding from heat.
  • trianglelaguna
  • trianglelaguna's Avatar
26 Jul 2010 16:22
#386020
dont use a flame by a battery imo...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • JR
  • JR's Avatar
27 Jul 2010 07:09
#386202
Flame, plastic, battery acid............recipe for disaster. Dangerous.
Bite the bullet and buy a new battery. Be safe.
  • Old Man Rock
  • Old Man Rock's Avatar
27 Jul 2010 07:31 - 27 Jul 2010 07:36
#386209
"Bite the bullet and buy a new battery. "....
No Doubt... :whistle:
How old is this battery to start with 1-2 years?
Your going to drive around trying to find all this crap or order on line (shipping charges) etc...
Not mention possibly get stranded somewhere when this thing goes to crap....
With all your other electrical posting issues, why go this route... :S All this for what, a $30 battery. Seriously, doesn't make sense...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 27 Jul 2010 07:36 by Old Man Rock.
