- Thank you received: 3
wiring up dynatek coils.
- Lazyman06
25 Jul 2010 16:10 #385706
by Lazyman06
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
Replied by Lazyman06 on topic wiring up dynatek coils.
I'm gonna worry myself sick about this. I know you said they would work Patton but a d\Dyna ignition is still quite a bit away. I've been reading up and one person was saying 3.0 ohm coils would be perfect for the bike while another said that the stock coils were 1.2 ohms so now i'm thinking 3.0 is too high. would it be more in the right range now that the resistor is gone? Do I need to order different coils?
- MFolks
- Thank you received: 540
25 Jul 2010 17:08 #385726
by MFolks
Replied by MFolks on topic wiring up dynatek coils.
This is from my factory shop manual:
"Primary(small wires) side of the coils will read between 1.8 to 3.0 ohms." I would not worry about what you've got as long as the produced spark ignites the air/gasoline mix and runs the engine.
- Thank you received: 2098
25 Jul 2010 17:41 #385741
by Patton
Replied by Patton on topic wiring up dynatek coils.
Here's what the FSM says about the resistor on 1979 KZ1000 which introduced the igniter style ignition as replacement for the former points style ignition.
The resistor limits the amount of primary current flowing through the coil to a safe maximum to prevent over-heating of the ignition coil primary winding whose electrical resistance is low to ensure a high performance spark.
25 Jul 2010 17:50 - 25 Jul 2010 17:52 #385743
by Patton
As I recall, there's a significant difference in dwell times between the igniter and Dyna-S style electronic ignitions.
But don't remember the specifics and electronic reasoning involved.
Would be comfortable relying on advice from the good and highly knowledgeable folks at Z1E
And would also agree with MFolks to not worry about what you've got as long as the produced spark ignites the air/gasoline mix and runs the engine.
Last edit: 25 Jul 2010 17:52 by Patton.
25 Jul 2010 17:56 #385746
by Patton
If not already done, would visually observe spark quality while spinning engine with spark plugs removed and bases held grounded against the engine head.
A fat blue spark means good-to-go.
- Lazyman06
25 Jul 2010 18:12 #385750
by Lazyman06
Sweet I appreciate it guys I feel better about it now. still have painting the engine and finish cleaning the carbs and reassembly than we can fire it off
- loudhvx
- Thank you received: 1616
25 Jul 2010 22:45 #385818
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic wiring up dynatek coils.
I use 3 ohm Accels with the stock ignition and they work fine. The Dyna 3-ohms are similar.
Ideally, you want 2.2 to 2.3 ohm coils. That is what the ignition was meant to use. I believe the first year electronic ignitions used resistors and lower resistance coils because they didn't have a source for the 2.3 ohm coils yet. Shortly after that, they went to the 2.3 ohm coils with no resistor.
The 3 ohm coils are a little slower to charge so they will likely have a little less spark energy/duration at higher RPMs. If the bike runs fine, then no worries. If the bike seems to stumble at higher RPMs, you can get lower resistance (2.2 ohm) coils or you can get the Dyna S which works well with the 3 ohm coils.
1981 KZ550 D1 gpz.
Other links.
- Old Man Rock
- Thank you received: 225
26 Jul 2010 06:20 #385864
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic wiring up dynatek coils.
Do yourself a big favor (to stop worrying about it) and swap both coils and ignition module simultaneously....
This way you'll have the correct resistance, you'll have the correct/ideal current draws and you'll obtain the performance you're trying to obtain in the ignition spark and timings...
I know, I know ($$$) but for another $120, swap them both and be done with it.... How can you go wrong....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Lazyman06
26 Jul 2010 15:42 #386007
by Lazyman06
I just looked at what bills are coming out next month and i'll have a paycheck and a half towards bike stuff so that ignition may be closer than I thought
