Dyna S ignition problem
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Dyna S ignition problem
24 Jul 2010 10:36
#385263
I use kind of a backyard/oldschool method I guess.
With the plugs in the wire caps, i just connect jumper cables. Each cable end holds 2 plugs perfect, then ground them to the frame/engine/whatever I can find.
Then, when I'm cranking, i know they have a good ground cause I can see them all sparking away.
This is a good setup for quick diagnostics, turning the ignition off/on.
If your a newbie who might forget the ignition on, or take long time to think/examine things etc. i would deffinately consider just removing the power wires to the coils (as mentioned), and be done with the whole possibility of damage/failure.
Cheers.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • loudhvx
  • loudhvx's Avatar
24 Jul 2010 10:52
#385266
Cheers.
B)
Very good tip.
You can just connect the bodies of both plugs together without actually going to ground, and it should work just the same. This is usually how I bench test ignitions. I just tie the plugs together with a rubber band or tape.
  • baldy110
  • baldy110's Avatar Topic Author
24 Jul 2010 18:13
#385374
I usually unplug the red wire coming from the Dyna S when I do compression checks but I got in a hurry and didn't this time. My bad. Thanks Mark but I just ordered up a new Dyna S. I will keep the other good module in case I do the same stupid mistake later.
  • SteveB
  • SteveB's Avatar
31 Mar 2019 01:16
#801316
MFolks wrote: One weak area on the Dyna "S" is where the power wire is spliced into the bike's wiring.
This type of connection is a real pain to troubleshoot due to moisture getting into the joint and corroding. Even though the connection may look good, it may not be electrically connected.
For a much better connection, I recommend soldering the connection and then covering it with heat shrink tubing.
I felt compelled to join this forum to say thanks to MFolks for this advice - I had issues with cylinders 1 & 4 and was convinced it was the coil as when I touched the HT leads feeding this coil the motor would cut-out. It would also cut-out under load but was ok ticking over. The little blue connector that MFolks mentions had a loose connection and was being moved when I touched the HT leads. I recrimped it tightly and bingo, problem solved. It's only taken a week to sort that annoying problem but I am so relieved it hasn't cost me anything but time!
Thanks again - these forums are a goldmine of information.
1978 KZ1000A2
The following user(s) said Thank You: loudhvx, DOHC
