1978 KZ 200 not starting urgent!!!
- JoeKz200
- i want help please
22 Jul 2010 19:13
HEY I NEED SOME URGENT HELP.
I recently bought this bike for 600 bucks and i changed the ignition coil and it ran fine for that night then today i tried to start it but it wont start. the spark plug is getting fire but it seems like its skipping its not firing every time and it has gas. and the battery is fully charged.
if the ignition coil is bad would the spark plug still be getting fire? I need some urgent help please
the ignition coil is getting hot/warm is that bad.
1978 Kz200
- Motor Head
Re: 1978 KZ 200 not starting urgent!!!
22 Jul 2010 19:39
Have you got a good manual? Sounds to me like you need to look at the points and condenser. Also you may have a issue with low voltage on the ignition circuit. Do you have a DVOM? Test Light? Some way to be sure of circuit integrity?
