Amperage output?
- polkat
Amperage output?
22 Jul 2010 14:09 - 22 Jul 2010 14:21
Does anybody know the peak output in amps (not volts) of an '82 KZ750-4 alternator (three phase type)?
And is the peak voltage output at high rpm about 50?
Thanks!
Thanks!
Last edit: 22 Jul 2010 14:21 by polkat.
- otakar
Re: Amperage output?
22 Jul 2010 15:08 - 22 Jul 2010 15:10
They had about 19A output max @ 10,000RPM
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 22 Jul 2010 15:10 by otakar.
- steell
22 Jul 2010 20:31
They are rated at 280 watts max output, so divide that by the voltage and you'll have the amps.
Manual says 50 volts AC between any two of the yellow wires, but it don't say at what rpm. I think the Factory Manual says 4000 rpm, but it's not at hand right now.
- otakar
23 Jul 2010 04:58
My rating in the Factory Kawasaki manual states @10,000 RPM.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- cafekz750
23 Jul 2010 07:47 - 23 Jul 2010 09:04
polkat wrote:
From the KZ750 FSM.
17A@10000rpm, 14V
Thanks!
From the KZ750 FSM.
17A@10000rpm, 14V
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
Last edit: 23 Jul 2010 09:04 by cafekz750.
- steell
23 Jul 2010 14:24
17 amps at 14V is less than the 280 watts listed in one of my manuals, bout 3 amps less.
But then again, the manuals out there, and I'm in here, so my memory has probably failed me again :dry:
