1981 mandated gauges suck
- supmonkeyface
21 Jul 2010 19:30
I've got a 1981 kz750e2, it has the mandated gauges that only go to 85 mph, with 55 mph highlighted in red.
I'm not saying 85 is not enough, its just that I pin the speedo so easy and then I cannot tell how much faster I am going. I don't ride like an idiot, i mean everyone's gotta let loose at the right moments.
The question i'm getting to is, can any other un-mandated gauge be substituted for my current one, or is there a modification I can perform to make this speedo read semi-accurately up to 100 mph? (I like knowing when i hit the ton). If it's a stupid idea or too much work i wont bother, i'll just ride beside a friends stang or something.
Thanks for any help guys.
- loudhvx
Re: 1981 mandated gauges suck
21 Jul 2010 19:45
Look at the RPMs when you are going 50mph, then double the RPMs will be 100mph.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- The Milkman
21 Jul 2010 19:52
The speedometers should interchange. Just find one on Ebay that has the same size front tire that you have.
- supmonkeyface
21 Jul 2010 20:00
loudhvx: Thanks for your very valid suggestion, until or if I cannot get a new setup for my bike I shall use this idea. Thanks
Milkman: Thanks for your info also, that's one of the things i was wondering also, was if the speedos from different years/models will bolt right up and use the same cable. I'll start researching similar wheel size models.
- otakar
21 Jul 2010 20:04
I had a 81 KZ1000CSR that had the same problem. I mounted a set of gauges from an 84 ZN1100 Spectra. They go to 160MPH
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- H1Vindicator
Last edit: 20 Feb 2013 20:23 by H1Vindicator.
- hocbj23
22 Jul 2010 10:14
Does ur bike use a speedo with a cable drive or is it electric? I have a couple of speedos here I would be willing to part with if u can use them.bj
- supmonkeyface
22 Jul 2010 16:41
hocbj23 wrote:
It has a cable driven speedo. Send me an email or something with details.
I was also wondering if the whole instrument panel will have to come off, and if that is hard to do with all the wires, etc.
