No Horn.
- kmshaffer
No Horn.
10 Apr 2006 12:55
My horn hasn't been working. When I first got it it was weak. I adjusted the horn and it was fine. Then one day I had some smoke coming out of my left hand controls. I opened them up and found the horn wire to be not hooked up to anything. I taped it up and there was no smoke, everything else worked good. I tried some things and finally got the horn to work, until I screwed the control back to the handle bars, then it wouldn't work once i got it tight. Here is the wire, does anyone know where I need to attach it and if there is anythign else I need to do.
Post edited by: kmshaffer, at: 2006/04/10 15:56
- fixer5000
Re: No Horn.
10 Apr 2006 13:20
it would be really helpful if youd put what bike you have in your signature on the bottom of the post..it sure makes it easier to help you troubleshoot your bike this way dont you think? since i have no idea what bike youre talking about i cant help you and i think thats why nobody has answered your post yet...there are a lot of helpful people here just dying to answer your questions...give us a bit of info please!! ready to help...steve
1978 kz650b pretty much stock
massachusetts
massachusetts
- rstnick
Re: No Horn.
10 Apr 2006 20:34
Try connecting it to one of the contacts on the backside of the switch. I can't remember off hand which one it connects to. I could look tomorrow in the daylight. The switch housing usually needs to be grounded to the handle bars as well, so if you have painted/black bars, the housing may not be grounding well.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- kmshaffer
Re: No Horn.
11 Apr 2006 05:22
Thanks Steve, I got the signature on. also I got the horn fixed. I had everything right, btut I just replaced the whole wire from the horn to switch and it's ok now. Thanks
