condenser.. kz 1000
  • kzjames
  • kzjames's Avatar Topic Author
condenser.. kz 1000
10 Apr 2006 11:21
#38304
I want to move to an enectronic ignition set up, however.. I am a little aprehensive.
I have points on the 77 kz 1000. I have had 3 sets of condensers go bad (just one side- but you cant replace just one side) in the past 3 years. I am concerned that whatever is burning out the condensor will also cause problems with the electronic ignition.. and it will be a much more expensive problem than replacing the $8 condensor unit....
what would cause a condensor to burn out, short or whatever it is that makes it bad?
  • steell
  • steell's Avatar
Re: condenser.. kz 1000
10 Apr 2006 13:29
#38330
Heat and vibration would be my guess, excessive voltage would do it also, but you would have other indications if that were the cause (like light bulbs blowing).
  • loudhvx
  • loudhvx's Avatar
10 Apr 2006 23:01
#38545
Ignition coils could possibly cause a condenser to go bad, I suppose. Try swapping ignition coils and see if that causes the other condenser to go bad.
While you're at it, check that both have around 4 ohms resistance on the primary side.
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: kettering ignition (breaker points)
11 Apr 2006 04:10
#38558
Read about it here .
Not shown is a series resistor, battery to coil. This limits the peak current into and out of the coils primary.
  • kzjames
11 Apr 2006 05:28
#38570
Thanks. Nothing else burning out. I have had electrical issues with this bike before (why can't I ever just buy a NEW bike) but I thought I was past those issues...
