Starter Issues
  • csutke
  • csutke's Avatar Topic Author
Re: Starter Issues
17 Jul 2010 22:40
#383536
Thats good info thanks for sharing. Ill try that along with the changing the oil.
  • OnkelB
  • OnkelB's Avatar
Re: Starter Issues
18 Jul 2010 12:27 - 18 Jul 2010 12:27
#383645
On the 650s/750 fours the starter clutch isn't located behind the alternator rotor, it sits in the center of the engine on the secondary shaft tied to the crank shaft by the primary chain.
You might want to read this (pdf file):
kzrider.com/index.php?option=com_docman&...d&gid=389&Itemid=108
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 18 Jul 2010 12:27 by OnkelB.
  • csutke
Re: Starter Issues
18 Jul 2010 22:33
#383762
the link seams to be broken, I can load it. If you PM me i will give you my email address.
Thanks
CSU
  • OnkelB
  • OnkelB's Avatar
Re: Starter Issues
19 Jul 2010 01:57
#383784
Yeah, link seems to be incorrect, sorry.
This one should work better:
CLICK
  • csutke
Re: Starter Issues
19 Jul 2010 12:37
#383856
that worked that time, thanks.
  • csutke
Re: Starter Issues
27 Jul 2010 16:08
#386349
So another question for ya'll bike masters. Ive been looking at parts for my bike at bikebandit.com and the earliest KZ650 they list is a 78 KZ650. I have a 77 KZ650, so do any of you gurus out there know if the parts are going to be interchangeable, or close enough that ordering them will be ok? Cause as of right now there are only two place that I can find that will have the parts needed, first being bikebandit and the other being the dealer. Id prefer not to go the dealer route as it will be way more expensive., but I will if need be to ensure the right parts. Also anything else that I should be ordering while im at it? Would it be a good idea to get a replacement secondary shaft, starter sprocket, clutch assembly, etc.. and return or resell any parts that I dont use?
Thanks
CSU
  • MFolks
  • MFolks's Avatar
Re: Starter Issues
27 Jul 2010 18:35
#386384
Over at www.kawasakimotorcycle.org is forum member "Kopcicle" He's got a lot of experiance replacing 650 starter clutches(it can be pretty involving from what I've read).
