Starter Issues
  • csutke
  • csutke's Avatar Topic Author
Starter Issues
15 Jul 2010 14:12 - 15 Jul 2010 20:45
#382880
So Im new at this site and new to Bikes but I know that theres a problem with mine. Its a 77 KZ650 and it wont start. Ive pulled the starter and had my local dealer check it. They said that its good but very loud. I pulled it apart and checked out the brushes etc.. One thing that I did notice was that the gear that the starter engages in the case was a little loose. It moved about 1/4" side to side. Its number three in this schematic www.bikebandit.com/houseofmotorcycles/sh...ematic/m3236sch83404
Also when the starter is in and im trying to get it to start it make a very funny noise. It acts like it want to start but then it makes a sound like gears are grinding or something like that. My dad thinks that its kicking out. Heres a video that I tried to get of the sound, im not so sure if you'll be able to hear what is going on or not. If you listen it makes the noise at the end of me trying to start it. s172.photobucket.com/albums/w5/icdubois/...current=P7140090.mp4
Thanks for any input that you can help me with.
Last edit: 15 Jul 2010 20:45 by csutke.
  • MFolks
  • MFolks's Avatar
Re: Starter Issues
15 Jul 2010 14:23
#382881
It might be your over running clutch on the alternator rotor.
The bigger 4's clutches are behind the rotor. They are three springs,rollers,and spring caps.
Over Running Starter Clutch Repair On the Older, Bigger 4’S
1. When preparing to repair the starter over running clutch have a few items on hand:
A. New alternator cover gasket.
B. New springs (3).
C. New spring caps (3).
D. New rollers (3).
2. If possible, put the motorcycle on the center stand and tilt to the right to reduce the oil volume in the alternator cover.
3. Place an oil catch pan under the left side of the engine to collect what small amount of oil that will escape when the alternator cover is removed.
4. Remove the foot shifter lever, left foot peg assembly and the sprocket cover.
5. Some Kawasaki’s have socket head cap screws(Allen type) and others may have fasteners with a Phillips type. If the latter is there, a # 3 bit seems to work the best for removal.
6. Remove the alternator cover and take care with the three wires coming from the alternator stator. These are the voltage supply wires for the motorcycle. Rest the cover on some newspaper or rags to prevent damage.
7. The magnetic Rotor or flywheel will probably require a removal bolt or puller. NOTE, SOME ENGINES HAVE LEFT HAND THREADS ON THE ROTOR!!
8. The over running clutch is bolted to the back of the rotor with three Allen head fasteners.
9. Separate the rotor from the over running clutch and inspect for damage in the springs, rollers, and spring caps. Replace any worn parts.
10. Re-assemble in reverse order taking care when re-installing the Alternator cover not to pinch any wires. If the cover will not re-install without force, check before any damage occurs.
Also what grade and type of oil are you using? Some of the cars oils have a friction modifier that will make clutches slip.
  • csutke
Re: Starter Issues
15 Jul 2010 14:45
#382883
Im not sure what oil is in it. I havent changed the oil in it. I will do this first as to see if that makes a difference. What oil would be best to use for this? Where is a good place to get filters for it? Also I have a clymer manual where would the steps that you have listed in it be in this? And the parts that you have listed, would these be a dealer only item or somewhere else.
Sorry for all the questions but like i said im new and trying to learn.
Thanks
  • MFolks
  • MFolks's Avatar
Re: Starter Issues
15 Jul 2010 15:02
#382887
Best Oils To Use In Your Bike (Just My Opinion)
Engine oil : The commercial grade oils are clearly superior to the mass market oils. For the best protection in your bike or car, use Shell Rotella Synthetic, available at Wal-Mart in blue containers . For the best petroleum oil you can buy, get Shell Rotella T, Mobil Delvac 1300, or Chevron Delo 400, available at any auto parts store. On the back of most oil cans is a circular stamp with the certification. Avoid oils that say "energy conserving" in the bottom half of the donut. These oils contain friction modifier additives that could cause clutch slipping over time. All XXw-20 and XXw-30 oils are energy conserving, and should not be used in your motorcycle. Don't buy any oil additives like STP or Slick-50. Here's several listings on all about oil justifying these conclusions.
The Recommended Synthetic Oils :
5w-40 Delvac 1 Synthetic
5w-40 Mobil-1 SUV/Truck Synthetic
5w-40 AMSOil AMF Synthetic
10w-40 Golden Spectro Synthetic
10w-50 Motul 5100 Synthetic
10w-40 Mobil-1 Synthetic
15w-50 Mobil-1 MX4T Synthetic
The best synthetics are: (in no particular order)
Shell Rotella-T Synthetic 5w-40 (blue container, not white), gallon at Wal-Mart.
Mobil Delvac-1 5w-40 (grey container, not black), gallon at Petro stations, gallon at Farm and Fleet.
Mobil-1 SUV 5w-40, qt anywhere.
AMSOil AMF 10w-40 synthetic motorcycle oil.
Golden Spectro Supreme, (no price).
Motul 5100 Ester, (no price).
Mobil-1 automotive oils all contain small amounts of moly - about 100 to 200 ppm. This can cause clutch slippage in some motorcycles. I've only heard of this being a problem in Honda Shadows.
For temperatures below -40, I strongly recommend either Mobil-1 0w-30 or the Canadian Shell 0w-40 Rotella. At these temperatures, your car is your life. Using cheap or incorrect oil is risking your life.
For temperatures below -55c, -65f, stay home. Really.
The Recommended Petroleum Oils
Chevron Delo 400 15w-40
Delvac 1300 15w-40
Shell Rotella 15w-40
The best petroleum oils are: (in no particular order)
Chevron Delo 400 15w-40 (blue container) gallon at any auto parts store, gallons at Costco.
Mobil Delvac 1300 15w-40 (black container) gallon at any auto parts store, gallons at Sam's Club.
Shell Rotella-T 15w-40 (white container) gallon at Wall-Mart or any auto parts store, gallons at Sam's Club.
If you live in another country, you'll have to do a bit of research to decide on an oil. Generally, any oil certified for use in a late model Volks wagon or Mercedes turbo diesel is a good choice. Another good idea is to go to a truck stop and ask the truckers about brands. Rotella is marketed all over the world, but in other countries it's called Rotella or Rimola or Helix Ultra, and the formulation may be a bit different, depending on local climate and preferences. It will likely also be a lot more expensive than it is here.
It also depends on how hot it gets where you live. Arizona and Texas riders are probably using 20W50 oil in their bikes, but in cooler states 15W40 would probably work.
  • MFolks
  • MFolks's Avatar
Re: Starter Issues
15 Jul 2010 15:05
#382889
To answer your question about parts for your bike, I'd suggest going to www.z1enterprises.com first and then the local dealer for starter cluch parts.
Z1 can probably get your oil filter and the O rings it needs for sealing the filter.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Starter Issues
15 Jul 2010 15:13 - 15 Jul 2010 15:15
#382890
Z1 Enterprises
As for the clymer manual, just read the whole thing! :laugh:
I always use AMSOIL 20W50 Synthetic. Designed for high performance air cooled bikes.
GL!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 15 Jul 2010 15:15 by TeK9iNe.
  • csutke
Re: Starter Issues
15 Jul 2010 16:21
#382902
B. New springs (3).
D. New rollers (3).
Are these parts #10-12 in the above schematic?
  • MFolks
  • MFolks's Avatar
Re: Starter Issues
15 Jul 2010 16:51
#382910
You'll have to research the numbers(Kawasaki numbers if possible) as the page is no longer available according to bike bandit.
Have you tried www.babbitsonline.com ? they have a similar website like bike bandit's.
  • Vter Bob
  • Vter Bob's Avatar
Re: Starter Issues
15 Jul 2010 17:46
#382921
I'm not going to touch the oil debate, but as far as filters go I'd suggest going to any good auto parts store that sells WIX Filters and pick up a Filter #24941. They are 6 - 8 bucks and come with both o-rings you need. Don't use "orange" filters.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
  • csutke
Re: Starter Issues
15 Jul 2010 20:46
#382979
fixed link, sorry
  • csutke
Re: Starter Issues
17 Jul 2010 00:08
#383269
I was talking to someone and they said that it might be the starter solenoid, is this a possibility?
  • MFolks
  • MFolks's Avatar
Re: Starter Issues
17 Jul 2010 08:32
#383308
Starter Solenoid/Motor Checkout Procedure
Some simple steps to determine what is working and what's not:
1.Fully charge and test the battery(most bike shops can load test the battery, and then use a floating ball hydrometer to check specific gravity in the charged cells).
2.Clean all battery terminals of corrosion.
3.Tighten all starting related connections(Positive RED(+) battery terminal, Negative BLACK(-)terminal) and from the terminal to the engine case. All connections must be clean and tight.
4.Clean the cable from the starter solenoid to the starter motor.
5.Clean and check the "bullet connectors" going to the coil side of the starter solenoid.
6.Try again to start the bike, keep in mind some Kawasaki’s have a clutch interlock to prevent cranking the engine while it’s in gear, so the clutch lever must be squeezed.
7.If no luck, go to step #8
8.Wearing eye protection, bridge with pliers or a screwdriver the two heavy duty(large)terminals on the solenoid. If the bike cranks, your solenoid may be bad.
9. If the starter won’t turn over, one of several things has happened; The starter motor has seized due to brushes binding up, lack of lubrication in the bushings of the motor, the battery is weak , the engine has seized or it could be a combination of any of the above. Some websites for starter motor rebuild kits are:
A. www.mawonline.com/newsite/rick_s_motorsp...-starter_brushes.htm
B. www.cyclewareables.com/pages/street_star...kits/startmtrkit.htm (not sure if the website is still viable)
10.The dealer may want $$$ for a new solenoid, but take your old one along and visit the nearest riding lawn mower shop. They have solenoids for about $15 that with a little work will fit. Be aware that the new solenoid from the lawn mower shop may require a ground wire for it to work.
11. I’d recommend upgrading from the existing battery cables to at least 6 gauge welding cables.
They are available in two colors(RED and BLACK) have more flexibility due to being constructed with finer conductors, and will fit in tighter areas.
12. The welding cable is sold by the foot, so take careful measurements or bring your old cables along. Most battery shops might be able to supply the cable too, so call to find out. The battery shop should be able to crimp/swage on the end of the welding cable the terminal ends or lugs using either a dedicated crimping machine or a tool that looks like a bolt cutter that has special dies to terminate the cable.
