rectifier regulator
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
rectifier regulator
14 Jul 2010 22:51
1982 KZ1100 again.
I am going to replace the rec/reg and I have a spare.
what I want to know is there a way to check my spare.
The red connector on my reg/rec had a burnt peace on it ware the black wire is.
- Old Man Rock
Re: rectifier regulator
15 Jul 2010 04:43
Follow the link to download the OEM Service manual... Has the rect/reg electrical testing procedures for your KZ...
Right Click the manual image below and "Save Link As" to download the PDF KZ1100 manual. This is a 76MB download.
www.kawiworld.com/index.php?option=com_c...icle&id=77&Itemid=99
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- loudhvx
15 Jul 2010 07:25
Most off-the-bike tests can only confirm it is dead. They can't confirm it is good. Do the tests, but if it passes all of them, you still have to put it on the bike to see if it's actually good. This is because it won't see the load and heat and vibration which may be a factor if it's flakey.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- TeK9iNe
- What did you do!?!
15 Jul 2010 07:45
loudhvx wrote:
this is the only way i've figured out how to properly test these. they are subject to a totally different environment on the bike, than on a bench.
I get everything hooked up, then clip a small volt meter to the battery, tape the unit to the tank, then go for a ride and keep an eye on it.
you'll quickly know if its working properly after a good 30 mins+ of riding.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
