Will these work for rewiring connections
  • eddyshore
  • eddyshore's Avatar Topic Author
12 Jul 2010 08:09
#381944
I got these at autozone seem to have a pretty good tight seal but I dont want to start if they wont work .
www.amazon.com/Curt-Manufacturing-I-4220...S/ref=pd_sbs_auto_36
Thanks
James
1979 KZ650 Cafe Racer Project
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Will these work for rewiring connections
12 Jul 2010 08:13
#381946
These are butt splices, not quick-disconnects.
If this is what your wanting then solder would be the preferred method of joining two conductors Then heat shrink around the non jacketed joint....
But yes, they will work if crimped correctly...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • eddyshore
12 Jul 2010 08:25
#381949
So if I am crimping them they should still work ? I can find any connector that match what is on the bike . These seem more readily available . I am connecting to the main harness .
  • MFolks
  • MFolks's Avatar
12 Jul 2010 08:37
#381951
I would only use them in a situation that did not have moisture. The crimp might be good, but it's not sealed against water intrusion.
This type is much better but requires a heat gun to shrink it after crimping:
Heat Shrink Butt Splices From Cable Organizers
www.cableorganizers.com
NSPA-KS5-16 18-20 AWG RED 50 $13.49
NSPA-KS5-14 14-16 AWG BLUE 50 $13.82
NSPA-KS5-10 10-12 AWG YELLOW 50 $16.48
www.easternbeaver.com offers the Japanese "Bullet Connector" type of electrical disconnects found on motorcycles.
12 Jul 2010 08:39 - 12 Jul 2010 08:41
#381952
Both bullet and spade style connectors are readily available, and may be preferable to the more permanent butt connector.
Usually come in both solder and crimp styles, and for different size wires.
Good Fortune! :)
Last edit: 12 Jul 2010 08:41 by Patton.
  • otakar
  • otakar's Avatar
12 Jul 2010 11:06
#381992
OMR
How do you splice a "butt" and why would you want to? Would that be if you have one that looks like this.
to make it look like this?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Vter Bob
  • Vter Bob's Avatar
12 Jul 2010 19:00
#382107
Ummm, I ain't sure, but that second one looks inflated, not spliced. That would certainly "crimp" your style however... :blink:
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
  • Old Man Rock
13 Jul 2010 03:18
#382210
Holly crapola...
Second Image... Baby's got Back no doubt! :blink: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
