Ignition Pulse Coil Assembly - REPLACEMENT
  • Hawk111
  • Hawk111's Avatar Topic Author
11 Jul 2010 19:01 - 11 Jul 2010 19:02
#381798
I am looking for a replacement pulse coil assembly.
That means the pulsar coils on the disk w/ points etc.
I would like a kz550c LTD 1981 part salvaged, however can't
find any on ebay - only a shitty one sold as broken. lame.
I just heard that the dyna s company has one that can fit, is this a good option.
In general does anybody know of any links to "any" ignition assembly I could buy that will work for this bike? Please help.
Last edit: 11 Jul 2010 19:02 by Hawk111.
  • otakar
  • otakar's Avatar
Re: Ignition Pulse Coil Assembly - REPLACEMENT
11 Jul 2010 19:19
#381801
The Dyna-S is an entire ignition system and is a definite option but is not as good as the OE Kawasaki ignition. The Dyna-S was intended as an alternative to points and not an upgrade to the Kawasaki IC Ignition. The Dyna-S is available from Z1E for $125. If you are interested, I have a set of like new Kawasaki pulsing coils for cheaper. PM me.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • MFolks
  • MFolks's Avatar
11 Jul 2010 19:29
#381803
To check out the pick up(pulsing coils) for the ignition system, use this procedure:
Ohm Checking Pickup(Pulsing) Coils
The pickup coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of X 100 check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S” electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6. Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
7.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
The forum member "Loudhvx" has made a replacenent for the Kawasaki IC Igniter using off the shelf GM electronic ignition modules.
With a good set of 3 ohm coils, the igniter construction diagram and the pulsing coils, you should be able to add this to your bike.
  • Hawk111
11 Jul 2010 19:38
#381807
What does pm mean? Got any pics?
  • otakar
  • otakar's Avatar
11 Jul 2010 19:52 - 11 Jul 2010 19:53
#381814
"Private Message" at the top right corner of the page. I sent you one. You will see a flashing green envelope up there. Just click on it. I can take a pic tomorrow and email it to you. Send me your email address threw the PM.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 11 Jul 2010 19:53 by otakar.
  • loudhvx
  • loudhvx's Avatar
11 Jul 2010 20:53
#381860
The Dyna S is reasonanbly priced, but the problem is that you should get new coils as well. Your stock coils are not recommended for use with the Dyna S. They will stress the Dyna S too much according to Dyna. Dyna recommends 3-ohm coils. Your stock ones will probably measure more like 2.5 ohms.
Thing is, you should probably get new coils anyway if they are the originals.
