dual headlights ???
  • gcarson64
  • gcarson64's Avatar Topic Author
dual headlights ???
09 Jul 2010 23:07
#381412
i am thinking about converting to dual streetfighter style headlights. whats the max voltage to stay under. and any other tips/suggestions. thanks.
1980 kz550 38,500 miles basket case ( soon to be a BOBBER )
1983 kz550 9,600 miles
1988 jeep grand wagoneer 144,500 miles 4 mpg
  • MFolks
  • MFolks's Avatar
Re: dual headlights ???
09 Jul 2010 23:18
#381415
I think you mean Wattage? It depends on your bikes charging system and what you plan on using for lights.
www.electrosport.com makes a higher output alternator stator(the stationary wire windings) that charges at a lower rpm than what came with the bike.
I'd recommend using two relays to carry the higher current rather than burning out your high/low beam switch.
If you plan on using plastic headlight housings,consider that they may melt/overheat at high wattage levels.
It's a do-able project, just some careful planning and purchasing will be needed.
