More voltage regulator weirdness!
  • polkat
  • polkat's Avatar Topic Author
05 Jul 2010 17:33 - 05 Jul 2010 17:39
#380451
Bike is a 1982 KZ750H3 4 cylinder. Recently I have posted with regulator/rectifier problems, complaining that my second unit has failed. I have done all the possible things like looking for shorts or open wires, bad connections, checking the phase outputs, etc with nothing
bad found. So I decided to pull the regulator and start looking for another one.
First I pulled the regulator output wire (red and white one) that feeds the battery...then I stopped. I decided to read that wire to ground for voltage with the engine idling just for kicks. I expected to see no voltage (as I assumed the regulator was dead). Instead, I got 35 volts!! Huh?? If it's putting out that much voltage at idle, why am I only seeing battery voltage at the battery when running with it hooked up??
I'm sure there is a simple explaination for this, so can someone fill me in? Thanks!
Last edit: 05 Jul 2010 17:39 by polkat.
  • loudhvx
  • loudhvx's Avatar
Re: More voltage regulator weirdness!
05 Jul 2010 23:07
#380528
When you pulled the red/white wire, there is no current flowing, that means there will be no voltage drop. If you put it under load, then the voltage will drop.
Could also be an intermittent problem on the reg/rec.
