1977 kz650b1 w/martek 440 ignition points
- lgj069
04 Jul 2010 21:18
Wanted to check the points on my bike. Took the side cover off and found another two piece cover. Could not get the second cover off because it has two nuts butted right up against each other and I did not want too destroy any thing. Does any body know how to get these covers off? Or, where can I get the instructions, or any information at all?Thanx for your time and efforts ... PEACE Larry
- loudhvx
Re: 1977 kz650b1 w/martek 440 ignition points
05 Jul 2010 02:31
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- loudhvx
05 Jul 2010 02:32
1981 KZ550 D1 gpz.
Other links.
Other links.
- lgj069
- lgj069
05 Jul 2010 11:43
loudhvx, I dont want to seem ungreatful, but my eyes are not what they used to be. I can not read the text in those instructions. If you could just tell me how to get that two piece cover off, in step four I think, I would be ever so greatful. Thanx for your time and efforts PEACE Larry
- loudhvx
05 Jul 2010 16:13 - 05 Jul 2010 16:20
Someone else scanned the instruction, so that file is all I have (if you click on it it gets a little bigger). But if I recall correctly, the rotor just pulls off.
Those are not covers, really. The inner one is the timing rotor and the outer doughnut is the main unit. It's been 10+ years since I've worked on a Martek, but I recall just pulling off the rotor. Then the doughnut comes off when you unscrew the three mounting screws.
But don't pull too hard if the thing is working, like I said, my memeory could be totally wrong. You may want to get confirmation from someone who knows better.
Sorry I can't be of more help.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 05 Jul 2010 16:20 by loudhvx.
- lgj069
05 Jul 2010 19:01
You have been a lot of help. Matter of fact, you are the only person who has made a real effort too help. I appreciate it.
You answered my question ... PEACE Larry
- otakar
06 Jul 2010 08:57
I have a Martek 440 K on my Z1R. I still have the instructions. I can scan them and email them to you if you PM me your email address. I love the Martek infrared ignition. I have it mounted with a set of Martek Blue Goose coils and WOW.
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- lgj069
06 Jul 2010 16:16
Otto, my email should be there. Thanx Larry
- otakar
08 Jul 2010 12:54
I emailed you the instruction sheets and diagrams for the 440. Let me know if they help.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- allank181
27 May 2012 01:12
Hi. I know this is an old post but if you are still out there otto is there a chance I could have a copy of the instructions also?
- peted57
06 Dec 2012 09:35
:woohoo:
6 months later . . .
Here's the fitting instructions etc, in PDF form for the Market 440K ignition system, 5 pages.
This is for the Z1 / Z1R / Z1000
Regards Super4 - Pete
