Alternative regulator/rectifier?
- polkat
04 Jul 2010 00:15
Well my second regulator/rectifier on my KZ750H3 has apparently burned out. I can't afford the new unit prices (I'm quite poor) and am tired of buying old stuff from Ebay that is probably near death when I get them.
I've heard about some people who have built their own units, or have modified other non-Kawa units to work at cheaper prices. Anyone here done that?
- otakar
Re: Alternative regulator/rectifier?
04 Jul 2010 09:44 - 04 Jul 2010 09:59
I don't trust the aftermarket units. I have heard horror stories about them. Namely that they don't last worth a squat. I personally have always had good luck with eBay parts. The used units are Seasoned and proven. You can try to build one from an automotive regulator. Or you have the choice to go with these guys.
www.accel-motorcycle.com/
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 04 Jul 2010 09:59 by otakar.
- MFolks
04 Jul 2010 11:07
Try here,said to have a life time warrenty on parts:
www.oregonmotorcycleparts.com
- Old Man Rock
04 Jul 2010 12:06
Since you've mentioned you've burned up two rectifier/regulator units... would seem to me you have a serious problem in your electrical system somewhere...
Partial shorting in harness/conductors or over-loading of electrical system... i.e. power/current electrical component consumption too large.
Wrong wattage lamps in head light, tail/stop light, blinkers, radio, CB, light kits, connector/switch voltage drops etc...
Or stator/Dyno is malfunctioning, not outputting ideal current...
Yes, electrical systems fail no doubt especially in a 30 year old KZ but based on your posting times of this KZ, to go through 2 rect/reg units in a year or less... naw something else most likely going on in your KZ....
Jeff has combo units for ~$120 w/shipping... Do yourself a favor, save some money for it and buy one of their units... Then go through the complete electrical testing/measurements start to finish thus insuring everything is operating optimally....
Otherwise, just keep going the route you have been with 30 year old e-bay items...
Building your own rectifier is a no brainer, ~ $10 for the rectifiers whether individual diodes (6 each) or full wave bridge units (2 each) and use the existing conductors/connectors from damaged units...
As for the regulators, unless you truly know what your doing in the SCR construction... naw don't go there....
Just a thought...
Just a thought...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
04 Jul 2010 12:12 - 04 Jul 2010 12:14
I have heard really good things about the new ACCEL parts and they are being sold for about $85+/-. The lifetime "Oregon ones also look pretty good. You can't beat a lifetime warranty.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 04 Jul 2010 12:14 by otakar.
- polkat
04 Jul 2010 20:06 - 04 Jul 2010 20:10
Bad choice of words on my part. They didn't burn out per say (no smoke and fire!) but just quit working. Both were old original units from Ebay. I do understand this stuff, and have the parts to build the rectifier, but I'm not up to designing the regulator on my own.
Traced everything today and found no problems other then the regulator/rectifier. Stator is putting out a good 50 volts in all three phases, no hot lines have continuity to ground, and tracing the wires point to point shows nothing wrong (no open wires or shorts). Just having bad luck with regulator/rectifiers I guess. Anyone got one in their tool shed I could buy, beg, borrow or steal (well...not steal)?
Yes, the Accell stuff looks good, but I'm unemployed long time now, and a step away from homeless, so that stuff is a bit beyond my finances.
Last edit: 04 Jul 2010 20:10 by polkat.
- bountyhunter
04 Jul 2010 21:29 - 04 Jul 2010 21:31
polkat wrote:
That experience has left me believing 30 year old electronics go straight to the dumpster.
Yep, just like the "good" used coil I got off fleabay that died in pretty quick order but didn't have the grace to do it convincingly so I screwed with other things like the jets while it was gradually dying.Well my second regulator/rectifier on my KZ750H3 has apparently burned out. I can't afford the new unit prices (I'm quite poor) and am tired of buying old stuff from Ebay that is probably near death when I get them.
Last edit: 04 Jul 2010 21:31 by bountyhunter.
