Rebuilding the dash?
- basketcase
03 Jul 2010 23:37 #380081
by basketcase
1979 KZ750B4
Basketcase
Rebuilding the dash? was created by basketcase
Going through the electrical I unbolted the dash to check all the bulbs. On trying to check the main info bulbs in the center I see the bulbs are too large to pull from the back. I don't want to bust this up but how can you pull the front from the back without damage?
TIA as always!
Jeff
TIA as always!
Jeff
1979 KZ750B4
Basketcase
- basketcase
04 Jul 2010 15:45 #380222
by basketcase
1979 KZ750B4
Basketcase
Replied by basketcase on topic Rebuilding the dash?
loosen ignition key unit and it pops apart.
1979 KZ750B4
Basketcase
- Beard
08 Jul 2010 09:45 #381036
by Beard
79 KZ650B
Jack of everything, Master of nothing.
Replied by Beard on topic Rebuilding the dash?
ummmm
"in the center I see the bulbs are too large to pull from the back"
i think u are saying the bulbs are too large to be pulled out from the back....
ur trying to pull the bulb and the rubber bulb holder boot out in one move?
just push the glass bulb in slightly and twist.. take the bulb out then pull the rubber boot out from the back?
79 KZ650B
