No power to headlight or tail light
- basketcase
03 Jul 2010 17:37
Got her running and now trying to trace the head/tail electric. There is no power to 2 of the 3 fuses with the key in run position.
Any help appreciated.
PS Krylon clear is NOT gasoline proof. Ruined about 10 hours of meticulous work
1979 KZ750B4
Basketcase
Basketcase
- MFolks
Re: No power to headlight or tail light
03 Jul 2010 17:50
Check the many and various electrical connectors. It's not uncommon to see power on one side of a connector and not the other.
Corrosion and/or damaged wiring can be a real problem to trace down.
The headlight housing has a large number of connectors inside. Plan on spending some time cleaning the connectors/doing wire repair.
Use two ways of inspecting the glass tubed fuses;
1.Remove the fuse from the clips, looking for tightness of the end caps.
2.Using either a self powered test light of a multimeter,continuity check the fuse element.
If a bad fuse(s) is found, AGX is the type of fuse usually in 10 or 20 amp ratings.
Clean the fuse clips with either a Dremel tool with a small wire brush or a cotton swab and metal polish(I use Brasso on mine).
