DIY Motorcycle Universal Gear Indicator
- kz.chris
- otakar
Re: DIY Motorcycle Universal Gear Indicator
02 Jul 2010 12:46
That's absolutely beautiful. I love it!
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- PLUMMEN
02 Jul 2010 16:52
just keep shifting till ya cant shift anymore! :laugh:
- Motor Head
02 Jul 2010 16:59
Looks like a cool project.
But isn't that what your tach is for, to low of RPM, downshift, to high upshift. You are either in the right gear or the wrong, personally I have yet to need a electric device displaying gears. And yes I drive manual transmissions in my vehicles as well. I would rather the TACH.
- otakar
02 Jul 2010 17:51
I definitely see a use for it. My gearing is so high that sometimes I'm in 4th and not in 5th. I know that i have to down shift down to second for best take off power. This will allow me to go down more than one gear safely without down-shifting too low. I have done that plenty enough. For vigorous riding that requires skipping gears sometimes it is fantastic. I'm definitely going to build one. You can buy them finished from a few companies for $250-$350.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- PLUMMEN
02 Jul 2010 19:30 - 02 Jul 2010 19:54
Last edit: 02 Jul 2010 19:54 by PLUMMEN.
- testarossa
02 Jul 2010 20:13
I love it! Thanks KZ.chris. Maybe not for the KZ, but I got one I can use it for.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- loudhvx
03 Jul 2010 10:01 - 03 Jul 2010 10:02
Seems like it could lose track of the gear if there is a shift into a false neutral, or if you don't fully shift. It's only sensing shifter up and down movement. Apparently it uses a signal from the neutral switch to "reset" it's position.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 03 Jul 2010 10:02 by loudhvx.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
03 Jul 2010 10:33
loudhvx wrote:
Yeah, that's what I was thinking too. Still, it looks like an interesting project, and I might want to give it a try--just for the fun of it.
West Linn, OR
